robfg67 Posted October 12, 2008 Share Posted October 12, 2008 All of these plugs are located near the steering wheel. This Large Black plug has 4 wires: • Red with white stripe • Black • Light Brown with black stripe • White with black stripe This Clear plug has 2 wires: • Black • Blue with yellow stripe This Black plug has 3 wires: • Black • Grey • Orange with white stripe This plug has 2 wires (a white & Green with black stripe) that were cut and are bypassing the plug: Link to comment Share on other sites More sharing options...
Akula69 Posted October 12, 2008 Share Posted October 12, 2008 OK - here goes: 1) Based upon where its coming off the harness, I believe (NOT sure) that it is your horn relay. 2) The brake switch for cruise control. Releases cruise when brake is tapped. 3) The cruise control dump valve switch. 4) I can't swear by it, but that looks like part of the windshield wiper harness, right about where the wiper delay module plugs in. HTH Jake Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 12, 2008 Share Posted October 12, 2008 Pretty sure #1 is for the Sentinel headlight delay module. Image Not Found Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 12, 2008 Share Posted October 12, 2008 Pretty sure #1 is for the Sentinel headlight delay module. That is correct, and if you would like one I have a few: http://www.comancheclub.com/forums/view ... hp?t=12302 and this is what it does, compliments of Hornbrod: "just turn the key off, pull the key, then shut off the headlights. They stay on about 30 seconds, then click off. If you don't want the delay feature, shut off the headlights first, then the ignition." Link to comment Share on other sites More sharing options...
james750 Posted October 12, 2008 Share Posted October 12, 2008 #3 is the interior courtesy light plug, the dump valve has a red piece of plastic underneath the female plug in. Link to comment Share on other sites More sharing options...
ejndssn Posted October 12, 2008 Share Posted October 12, 2008 Pretty sure #1 is for the Sentinel headlight delay module. That is correct, and if you would like one I have a few: http://www.comancheclub.com/forums/view ... hp?t=12302 and this is what it does, compliments of Hornbrod: "just turn the key off, pull the key, then shut off the headlights. They stay on about 30 seconds, then click off. If you don't want the delay feature, shut off the headlights first, then the ignition." what year model was thevdelay feature avail i may be interested for my 89 Link to comment Share on other sites More sharing options...
Akula69 Posted October 12, 2008 Share Posted October 12, 2008 #3 is the interior courtesy light plug, the dump valve has a red piece of plastic underneath the female plug in. Courtesy light plug has a pink hot lead, a black and a black w/ white tracer- not a red w/ white tracer. In the first picture you can see his courtesy light (yellow plug with rust colored bracket) in the background (even though it appears to be spliced into another set of wires). Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 13, 2008 Share Posted October 13, 2008 Pretty sure #1 is for the Sentinel headlight delay module. That is correct, and if you would like one I have a few: http://www.comancheclub.com/forums/view ... hp?t=12302 and this is what it does, compliments of Hornbrod: "just turn the key off, pull the key, then shut off the headlights. They stay on about 30 seconds, then click off. If you don't want the delay feature, shut off the headlights first, then the ignition." what year model was thevdelay feature avail i may be interested for my 89 According to Hornbrod all MJs except maybe '86 had them. All three of mine ('88,'89,'90) have the connector. It's not working in my '90, I need to check the voltages at the connectors and figure out what's wrong, but in my '88 and '89 it was plug and play. Link to comment Share on other sites More sharing options...
Xacto Posted October 13, 2008 Share Posted October 13, 2008 This Black plug has 3 wires: • Black • Grey • Orange with white stripe The wire colors match the description for the connection to the emissions maintenance timer: 20OR/WT 18BK 20GY Link to comment Share on other sites More sharing options...
Akula69 Posted October 13, 2008 Share Posted October 13, 2008 This Black plug has 3 wires: • Black • Grey • Orange with white stripe The wire colors match the description for the connection to the emissions maintenance timer: 20OR/WT 18BK 20GY He is right, I looked at mine and figured it out. 2 out of 4 or 50%. I failed :oops: Link to comment Share on other sites More sharing options...
robfg67 Posted October 13, 2008 Author Share Posted October 13, 2008 Thanks Guys, a wiper delay would be nice to add. Do I just need the correct stalk? Link to comment Share on other sites More sharing options...
