DirtyComanche Posted September 11, 2008 Posted September 11, 2008 Thinking of getting one for the 2drx4. Owners of a renix 4.0 know how silly the stock oil filter is mounted - vertically with the threads down. It means you're guarenteed to dump a fair amount of oil when you change it, and it might lead to priming issues. I know a guy can rotate the oil filter adapter, or run the newer style (HO) one which mounts the filter sideways. But that doesn't really fix the problem. But I saw this on summitracing: http://store.summitracing.com/partdetai ... toview=sku For $50 you could throw it somewhere else - the firewall assumably would be the best place if you could find the room. Then the filter is oriented correctly. And you can use a larger filter. They have a dual setup too, and they make them for the HO. Anybody already got one? Where'd ya mount it? I'm tempted to go this route for my next oil change. Any other thoughts?
JeepcoMJ Posted September 11, 2008 Posted September 11, 2008 I would say that it's a very good idea. if you have the room in the engine bay to relocate it, then heck yes.
gixxerman600 Posted September 11, 2008 Posted September 11, 2008 I did this on my old truck, the good news is it will hold more oil.
mjdoa Posted September 11, 2008 Posted September 11, 2008 And the bad news??? For those of us with thoughts of changing over.
Eagle Posted September 11, 2008 Posted September 11, 2008 The bad news is -- where the heck do you put it? There's no extra space in there at all.
mjdoa Posted September 11, 2008 Posted September 11, 2008 Yea,I thought about that,and I have a/c too!! I don't have room to carry a spare can of oil under there.
HOrnbrod Posted September 11, 2008 Posted September 11, 2008 Use the 1997+ washer bottle inside the fender well and you can do it like this: Image Not Found Image Not Found Image Not Found
Akula69 Posted September 11, 2008 Posted September 11, 2008 Say Hornbrod - where does the second line from the filter go? It appears to route towards the front - perhaps to an oil cooler? I have been thinking that this would be a good mod to help with the engine heat problem. As I understand it, a remote filter through a heavy-duty cooler could make a 15-30 degree difference in oil temp...possibly making a cooler block... just a thought.
HOrnbrod Posted September 11, 2008 Posted September 11, 2008 Say Hornbrod - where does the second line from the filter go? It appears to route towards the front - perhaps to an oil cooler? I have been thinking that this would be a good mod to help with the engine heat problem. As I understand it, a remote filter through a heavy-duty cooler could make a 15-30 degree difference in oil temp...possibly making a cooler block...just a thought. That's exactly right. These pics were sent to me from one of the guys on the stroker forum. He claims running the engine oil thru the cooler and remote filter made a big difference in the stroker engine temps.
