I would put that engine in my MJ in a heartbeat!
Is it just me, or does the skid plate under the transfer case appear really thick?
I know there are not many diesel choices for a swap.....but the 4bt is just not well suited for that vehicle.
Edit: Dur, its a b3.3
and here is the data sheethttp://www.cummins-sp.com/document_library/Spec_Sheets/Engines/Industrial/B3-3_Spec%20Sheet.pdf :cheers: i want one too jamminz.gif what else could be done maybe 16v & banks performance kit :brows:
Under Armor.. Very sweet Jeep.. To bad its sold.. (not that I can afford 28K)
If you see this post Pete,, The antenna on this Jeep is the one I was talking about not long ago.
