extended cab MJ ??
ICEBOX
Anyone have info or have done an extended cab MJ ??
how far are you looking at extension?
if you have a scrap MJ and cut the back of the cab off, simply putting 2 door cherokee doors in and adding 9" of cab will make somewhat of an extended cab. this is/was TNT's plan on the club here. you'd also have to shorten the front of the box.
otherwise, there have been a fair few of them around. one is built with a newer cherokee body and a comanche back half, and there are TONS of cheromanches out there as well.
