Limeyjeeper Posted June 26, 2008 Share Posted June 26, 2008 Does anybody know if a 2000 AW4 is a straight swap for a 1991? Did Jeep go electronic or can the 91 sensors/controller still be used with the 2000 trans. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted June 27, 2008 Share Posted June 27, 2008 No it's not a direct swap. -Lead_"been threw my fair share of AW4's"_Follow Link to comment Share on other sites More sharing options...
comancheman Posted June 27, 2008 Share Posted June 27, 2008 i thought the last year for the aw4 in jeeps was 97 and then they threw in some chrysler piece. whats the truth? Link to comment Share on other sites More sharing options...
gogetemturbo Posted June 27, 2008 Share Posted June 27, 2008 The AW-4 was used in the XJ until 2001 at the demise of the cherokee. Bolt in wise, the 2000 AW-4 with bolt right in. Wiring though is the problem. The 2000 (not sure year it started) AW has an extra sensor and requires the late model wiring harness. I ran into this problem in reverse, when I wanted to install a early AW-4 behind my 01 XJ motor I was putting in my MJ. I ended up spending the extra and getting the AW that was behind that 01 motor. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 27, 2008 Share Posted June 27, 2008 Bolt in wise, the 2000 AW-4 with bolt right in. Wiring though is the problem. The 2000 (not sure year it started) AW has an extra sensor and requires the late model wiring harness. Started in 97, OBDII. Link to comment Share on other sites More sharing options...
jtdesigns Posted June 27, 2008 Share Posted June 27, 2008 if you guys could gripe any about the aw4 what would they be?? I'm buying a xj and it makes a noise in park at idle.. Think it needs rebuilt? or replaced?? like whats the biggest problem for these trans? I had a older xj many years ago I remember it used to go in and out of overdrive or feel like it was trying to change gears on the highway.. Just want to brace myself for this 96 I'm getting... Link to comment Share on other sites More sharing options...
comancheman Posted June 27, 2008 Share Posted June 27, 2008 190k and shifts mint. i drain the pan at every oil change and throw in 3.5-4.5 quarts of tranny fluid. i also use a lucas transmission fix everyonce in awhile. i can't complain Link to comment Share on other sites More sharing options...
jtdesigns Posted June 27, 2008 Share Posted June 27, 2008 190k and shifts mint. i drain the pan at every oil change and throw in 3.5-4.5 quarts of tranny fluid. i also use a lucas transmission fix everyonce in awhile. i can't complain whats the recommended tranny fluid for the aw-4... please don't tell me its dextron III.... I just spent my lifes saving on a refill in my Rodeo and is highly recommended to use that $7 a qrt fluid.. Just ATF right?? Link to comment Share on other sites More sharing options...
mvusse Posted June 27, 2008 Share Posted June 27, 2008 Dexron III is just regular ATF. $2-something at Autozone. If you paid $7, either you were ripped off, or it was fully synthetic. Link to comment Share on other sites More sharing options...
reson46 Posted June 27, 2008 Share Posted June 27, 2008 190k and shifts mint. i drain the pan at every oil change and throw in 3.5-4.5 quarts of tranny fluid. i also use a lucas transmission fix everyonce in awhile. i can't complain whats the recommended tranny fluid for the aw-4... please don't tell me its dextron III.... I just spent my lifes saving on a refill in my Rodeo and is highly recommended to use that $7 a qrt fluid.. Just ATF right?? AW4s use Mercon/Dexron. Do NOT use Chrysler ATF+3/4 no matter what the dealer, repair shop, or idiot behind the counter at the parts store tells you. :D Willy Link to comment Share on other sites More sharing options...
