Everything posted by comanchedude
(In the few months I spent driving a wrecker, I saw more stupidity than in the rest of my life lol.) Now for some reason I just can’t stop laughing :)
Bob That looks like a top quality job, and some big bucks So what do they charge to do that? Also I talked to Pete about the overhead at the Pow Wow and I still have that on my to do list Let me know how the unit you bought works out or better yet I will check it out at winter fest
05 PowWow at The Badlands...
comanchedude replied to Pete M's topic in Adventure Planning / Regional Groups
Pete Got the cd today thanks Tons of pictures Funny thing you have a picture of a Comanche labeled kthkhgv "I guess from EBay" and I bought that Comanche 8) Thought that was funny Again thanks for the video as well much appreciated -
I live close to Cincinnati,or you could say the greater cincy area
87manche I have 4.10 gears in my 4x4 and currently run 31 inch trxus tires with a 4.0, AW4 and I can say you will have tons of power and torque. (I had the 3.07 gears and the difference feels like I swapped in a V8 now) I think you can run up to 33inch tires and still have acceptable power with 4.10 gears
Well Your in luck I have done that exact swap your about to do and it is not that bad And it is without a doubt the best upgade path I took a 4cy 2wd 5sp Comanche and swapped in a 4.0, auto, 4wd system into it First you need to pull all the items below from the 89 truck with the 4.0 1) Wire harness from “under the hood “that entails taking the complete harness from the front side of the firewall that’s it NOTING FROM INSIDE THECAB (except if auto tranny you will need the tranny computer but that will be part of the harness under the hood anyway) the wire harness basically bolts to the big connector on the driver side and wraps around the front of the truck around to the passenger fender and back to the center of the fire wall 2) After you remove the 4.0 engine with the tranny and transfer case “if 4x4’ you also need the engine mounts and (very important) you must also take the frame horns, that is the brackets bolted to the frame the engine mounts bold to. 3) You will need the 4.0 radiator (the front of the 88 4cy truck will be the same but you need to remove the spacer they bolt in for the 4cy radiator) it just unbolts 4) You need the 4.0 fuel pump (and tank if your 4cy was a carbureted version) 5) You will need to cut the 4.0 fuel supply hoses just before they mate to the steel lines at the frame of the truck, you need to splice these onto the 88 truck as the 4cy hoses have different ends and are to short 6) You will need to use the 4.0 rear drive shaft as well Things like the cross member are the same also think about stuff like do you have tilt wheel if not, does the 4.0 truck if so swap that also. You can swap a standard gauge cluster with one with gauges on these years just by swapping the cluster And other things Now I could have forgot to list something but this is the “must have” parts If you have some experience in engine swaps you will find this is not a big deal and I was able to do the complete swap in a week end with 2 helpers If you have any questions just send me email I can guide you through any part of the swap Now if you are not going to use the 4.0 driveline (tranny back) then you may need to work that part out as I used the driveline that came with the 4.0 Again I can help answer any questions that are related to the swap and would be more than happy to do so
Front end wobble above 40 mph
comanchedude replied to red_eyed_rider's topic in MJ Tech: Modification and Repairs
THATS THE SPIRIT :D -
1989 2WD CONVERSION 6 inch lift 4.0 ,AW4, AMC 20/DANA 30 FRT & RR LOCKERS 4.10gears, 33" Trxus Tires , custom bumpers,sliders
jeep has a lost of power after i shut it down.
comanchedude replied to bogginboy's topic in MJ Tech: Modification and Repairs
I would second pingpong Sounds like bad alt,and or a bad connection -
Pete Thanks for the Video it turned out good The cd I could not find a way to view -
Couple things come to mind If these are alloy wheels you may need the type of lug nuts that go down into the wheel? If these are steel wheels then my guess is they are not fitting over the center of the hub and that could be the problem? You would not need longer wheel studs! You should measure the back space of the wheel and see if it is less than the stock wheel if it is not less then just use your stock wheel until you’re ready to buy new wheels that have a 4inch back space
Thanks Pete I’m sure the video quality will be adequate -
can't wait to check out the videos :P -
well: my recomendation was not to start some debate ,it was to offer a soulution I don't know why some feel its importaint to start a debate in this type of fourm? Actually is contains "CSL" COPPER ,SILVER ,LEAD (if you know about this product you would know this) graphite is not in this product and would not help seal rings as graphite is just a lubricant it does not cause any problems with my Comanche oil gauge or any other viecical I have used it on also it will not clog anything as the particals are smaller than the media can trap. As for you link it does not address this type of product. (more directed at ptfe) I simply suggested a product that has worked for me to improve the compression on old engines and help the blowby. I don't claim to be an expert on the subject of oil additives and would not take some web site as the ""word" on the subject either.
I found a wholesaler that has them for $55 a pop. So 110 to do both sides isn't bad Let me know the name of this wholesaler as that is a super deal
All the other suggestions outstanding, You can try a product that works well it is called "engine restore" and it will help seal up the piston rings due to wear try it and you should feel an improvment in power and a reduction in cylinder blowby,I have used it for years on older engines and have noticed the improvment everytime In normal driving, friction and wear cut scratches in the metal surfaces inside every car's engine. This causes compression and power loss and increases oil consumption as cars get older. Restore Engine Restorer fills these scratches and improves the seal between piston rings and cylinder walls. This means better compression and more balanced compression across all cylinders. Independent road tests prove Restore brings back power to near original levels
Had a Geat time at Badlands Thanks for organizing the trip Peter is was perfect My son had a great time and thought everyone was "cool" I have burned the pictures my son took so if anyone wants a cd send me your addy and I will send you a copy Also Pete I want a copy of all the video you took, Thanks (If you need a blank cd or dvd I can send you one) Tom Laine 2079 Canary Ln Fairfield ,Ohio 45014 -
Scary noise coming from my 4.0L
comanchedude replied to Pete M's topic in MJ Tech: Modification and Repairs
Not sure if the sound is the same but I have similar sound when a couple of the rocker arms were getting cockeyed (crooked) due to wear I took them off cleaned them put them back on (field repair) They worked fine for the rest of the day next morning they made that sound again and one went completely 90deg and was off the valve So I replaced all the rockers pushrods and everything was good About a month later i replaced all the lifters as they were noisy Now the engine is very quiet and valve train is very tight So maybe check the play between the rockers and valves if it is very sloppy that could be the problem Just a thought My engine has 188 and the sound is basically what you described -
I plan to arrive Friday later in the day will camp So what is the final tally of folks making this pow wow? -
How do you rate the Mickey Thompson Baja Claws? I like the looks of them and I think I want to get a set ,do they perform very well off road?
I'm in also..Bob has a good idea -
Not me,I have Blue 88 Comanche Well that sounds good because I didnt want to dive that far if it was not better than haspin You can count me in for the October pow wow
I bought a new one from the dealer it was $30.00
comanchegirl I have been to Haspin several times, plan to go to Badlands next week end is it better that Haspin? Also I am only about 35 miles from Haspin so any time you want another Comanche to trail ride with let me know as it is hard to find folks to trail ride with
