CoryMJ89
Everything posted by CoryMJ89
Is there a company that makes the brace wrap around the bottom slop part under te cal tho?
Just wanted to stiffen te front mostly bc I have buddy who has had the unibody split right under the call where it dips down
Do it wrap around the bottom like other stiffners?
I know there beefyer than an xj body but wanna make strong as possible and stiffners beside the trac bar and steering box brace? Like actual weld on braces from steering box down to under the back of the cal?
I need to do unibody stiffners on my MJ but I've read on a couple naxja threads the TNT ones won't work at all not close with out major modifications.. I know that the MJ has extra supports coming down from the cab to the frame rails but I don't know much difference outside of that idk of rough stuff would work or not so I need some helps fellow manche owners who have experience with this thanks!
Make sure no front end damage front frame horns can be tweaked with the right amount of impact and bed the unibody
Anyone Used Rustys Over The Nuckle Steering Before?
CoryMJ89 replied to CoryMJ89's topic in MJ Tech: Modification and Repairs
Think I'm gunna go with froehlichsuspenion steering then coilovers and my wheeler is finished besides a Bobb job -
How Much Lift Does A Ford Soa Swap Give You?
CoryMJ89 replied to 1990manche's topic in MJ Tech: Modification and Repairs
But I started out by putting an 8.25 in and a 8.8 is a little bigger than an 8.25 bc the axle tubes are a little bigger around so prob around a 6 I'm guessing -
It gave me a 5.5 -6 the half inch can all depend on how tall ur spring perches are ect -
Help With 4X4 Conversion Parts
CoryMJ89 replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
If u have a 2wd tranny now in ur truck ur rear driveline won't work when u covert it to 4wd te tcase has more spline than the adaptor on the back the 2wd tranny I'm pretty sure I just put an sye kit straight in when I converted mine to 4wd and make sure u get all the mounting hardware that bolts to the undercarriage that all the shift linkages hook too front drivelines I think are all the same between as far as I know in 4wd cherokees -
If you want pure bolt on, take a look at OROs UTurn.http://www.offroadonly.com/products/new/u-turn/ But really, any OTK set up will not be straight bolt on. The JCR GM one ton set up should only require you to ream the knuckles (drill) for the TRE. Plus you can buy the TRE at any auto part store vs a special order part from Rusty. Why use 1 ton stuff? How would that even fit? -
Have to weld on a new mount and move the trAc bar up -
Bc I don't wanna build something just want something to drill out and put in -
I buying my 4.88s and front locker this week and ppl on here said the spartan locker is a good way to go from the feedback I got also bc the one pin spring set up thing but where should I get one for a reasonable price thanks?!
Mnkyboys 89 Comanche project
CoryMJ89 replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
What rear spring u running and do u know how much space there is from the edge of the bed to the shackle mount bc I was thinkin of cutting 10-11 inches off- 798 replies
- 2.5l
- supercharged
- (and 7 more)
The bed is double plate metal right like two layers? Instead of just a single side panel sheet?- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Was this originally a long bed?- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Need Pics Of Bobbed Comanche Short Bed
Couldn't find it -
going to bobb my bed once i find the right length so was wondering if i could see the bobb process and also one truck bobed 10 inches 11 inches and 12 inches. short bed only because thats what i have thanks guys :thumbsup:
Motive Gear Performance Anyone?
1 tooth? how many would a 4.56 have? just seems odd to me -
Yeah I just bought a 4series carrier! -
How much was the install kit bearing was tht all necessary -
Yeah that outa my budget
