Everything posted by Zebvance
Jeep Locked Up And Skid To A Stop... Almost Died.
Zebvance replied to Zebvance's topic in MJ Tech: Modification and Repairs
Sure enough the truck did it again and had to crawl home in 4x4. Pulled the diff and found all these goodies! -
just paid and put my order in for 3 coozies and a sticker. Prolly will order some more in a week or two. Thanks PETE!
Going to need measurements
What are they from and do the bolt right up?
What Pontiac seats are you talking about?
Wahoo!! Get paid weds and this will be the first thing I do!
glad to hear you made it good!
I have one. not sure if its the length you need. we need measurements from ujoint center to ujoing center
Pete I def want a few!!!
Whats up with the coozies pete?
If my MJ ever dies I will be in the market for a J10/20 the very next day!!!! I love them!!!
Datsun 280Z Hood Louver Install.
Zebvance replied to Zebvance's topic in MJ Tech: DIY Projects and Write-Ups
Holy clean MJ hornbrod -
the gauges..
oh block warmer...oh block warmer what are you doing here? This is Texas, Don't you know that there is one season here? Its called Hot! I would never plug you in because you are 25 years old and would probably give me a arson charge with the local PD... I know this Frankenstein, money pit, rust bucket of a mj came from the maple leaf land many many moons ago, hbut my questions are..... Should I dare to plug you in for $#!&s and giggles? How do you only have 100k miles? Why do you have a 1992 transfer-case? why do you have a 2001 Cherokee dana 30? What year is your rear Cherokee dana 35 out of? ( I need to change your brakes) Did you come with bucket seats? Did you really begin as a 2wd? What tramadic episode have you been in to have bondo on ALL FOUR corners of you? Why is there a E -Brake center console when I have a Floor E brake? ( that doesn't even work...) Why does your 4x4 light not work? Why do I always feel like I just got tetanus when I'm working on you? Why are you lifted 4.5 inches in the front and 9 inches in the back???!?!?!?!!?! YOU LOOK STUPID! Why is your roof dented, oil pan dented by you upper control arm mount, and trans cooling lines kinked like you have bee rolled over or something? Why do you have to have your gauges in OIL BARS, KPH, CELSIUS? ( thank goodness for a iPhone conversion apps....) Why do you have the door-less mod done to you but I cannot pull your doors off still? Well that's half of my frustration out for the world to see..... If only I had one more beer it would be twice as long.... Love yours truly.... THE PENNY SNIFFER
16k Is a bunch! I could put 1 tons, 35's, new paint job, 4.7 stroker, new tranny, and a long arm lift for less than that.... but I don't think anybody ib here would deny that, that is ONE CLEAN MJ!
Installing Exhaust Manifold
Zebvance replied to Keyav8r's topic in MJ Tech: Modification and Repairs
yes I did use never seize. look thought my build thread and I have picture and some info of when I replaced my intake manifold. Also While your there IF your motor mounts are in bad shape I would highly suggest replacing them at the same time. My build thread: http://comancheclub.com/topic/34531-1988-you-aint-chancin-unless-your-manchin-mj-build-pic-he/ -
I think that you would spend more time and effort doing that vs just pulling it all off.. I just replaced mine and I can't see how I would have done it with out pulling the intake. -
Ok so I'm going to pull the rear diff cover off then. I already have a 8.8 with 4.10ssitting in the garage just have got the bracket kit to put it on and still trying to get together stuff to regear the front at the same time. -
It was very loud and violent and it was not just the rear breaks locking up and coming to the stop because it was wet. That has happened to me plenty of times before in other cars. Is it possible the trans tried to down shift and locked up or Somthing? -
the truck has been converted to 4x4 by the PO. the engien has 105k on it. I have a 1991 np231 unknown mileage, that just had a sye installed with a tom woods drive shaft professionally and he said the transfer case looked very good inside. and I know nothing about the transmission. -
My 1988 jeep comanche 4.0 4x4 auto died on me over xmas break in my home town 2 1/2 hours away. long story short it was the cps. Left it there, got it repaired and ran fine. went to drive it 2 1/2 hours home tonight and got 1 mile from the house. I was slowing to a stop maybe 20 mph coming to a stop light and all the sudden my tires locked up and i came skidding (Storming bad also) to a stop and slid into the oncoming lane. It was still idling when it came to a stop fine. it was in drive, then pressed the gas and it wouldn't go anywhere. Reverse however worked. I had to reverse off the road through a ditch to get to a parking lot. I got stuck in the ditch, then tried 4wd. It wouldn't engage though, The tried drive and it went in. shimmied my way unstuck and felt it starting to sink again in the mud so i tried 4wd again and it worked. then reversed in 4wd out of the ditch and over the curb into the parking lot. After all that I got out looked around and everything seemed fine on the truck and drove it straight home?!?!?! no noises or anything really!!! WHAT THE HECK HAPPENED?!?!!?
although I have not confirmed it, I highly doubt my o2 sensor is bad. I just did a full exhaust revamp. Pacesetter header high flow cat, magnaflow muffler and running 2.5 inch pipe, with a brand new o2 sensor. This truck runs smother than it ever did before this. I have had the truck for 1 year in feb. bought it with around 99k and it has 103k on it now. With in those 4 thousand miles I have put atlease 3-4k$ into it. Just shy of a full rebuild the engine has ran great since I have done the work on it.
