lexluthier72
Everything posted by lexluthier72
Power steering fluid leak/cleanup?!?
lexluthier72 replied to lexluthier72's topic in MJ Tech: Modification and Repairs
Mule13....Its not spilled, its gunked up all over the inside of the engine bay. Jerry...Thanks! Good smelling is OK. 8) -
Intermittent steering creak?
Still have not "solved" this issue....have not had time yet, or funds. My plan is to buy a new Trac bar, and find a newer steering linkage/gear at the JY. (both recommendations from my buddy. Eagle: IF you read this, how do I "test" the lower control arms for noise/movement? -
DIY tonneau cover?
Thanks Mister! -
found.
Help!, My 'manche quit running
lexluthier72 replied to Jerry Forrester's topic in MJ Tech: Modification and Repairs
Defective coil new out of the box? Also....New HT coil wire? Id pull the coil you bought and have it tested, and if its bad, have them test a new replacement coil before you leave with it....just throwing out ideas. -
1990 Minnesota MJ Project: Preservation....
lexluthier72 replied to lexluthier72's topic in Member Projects: Your Comanches
Changed the alternator out today....and we have ALL seen an alternator right?!? Hehe....and I also finished this up....DIY Tonneau Cover....Here are the support rods: We used marine grade spray on waterproofing for canvas. Here is the cover installed: -
DIY tonneau cover?
Hey All, Here is an update: I got 2 crossmembers installed. The rod is 1/2inch conduit. the "rod cups" are PVC. There will be 3 of them, but the hardware store ran out of pvc. Here's the crossmembers: And....Here is the cover installed: It may take a couple days for the canvas to relax onto the bed rail/tailgate. We used a marine grade spray on waterproofing for canvas. It's supposed to rain tonight...we shall see.... :D -
Hey All, I am in need of a black "horn surround" (steering wheel pad) This is the one with the sort of rectangular horn button. IF you have one, PM me. Price shipped to 55407? Need asap. -Erin
Good thing there is an "off" button on Youtube...Ugh. :D
So...Always better to investigate in the daylight right? I'm not so sure my steering gear is leaking. The big hose that comes out of the resevoir IS leaking at the hose clamp. (I tightened it carefully) My only question here is, what can I use to get all of the steering fluid cleaned up? Will a standard de-greaser work? -E.
Gee thanks guys...all this banter is helpful in finding what I'm looking for. Hard to drive with this thing flopping around. (I do live in the city, and it is a DD) I thought in a group dedicated to Comanches, maybe a few people might have an extra (that I could buy) Maybe I need to go to ebay? There is only one MJ in the boneyard (hour and a half away) and its already been stripped clean. Please only post if you have what I need. -E. EDIT: Mechanic FIRED! What a knucklehead! :fs1:
Hey All, So...My so called "mechanic" buddy is turning out to be less than reliable in the "giving a crap" dept. I was changing out the alternator tonight (its making noise) and happened to notice fresh wet spot near the steering gear. Previously there was "old" leakage evidence. I stuck my hand under the steering gear and it was fairly fresh fluid leak. I previously did not feel any clunk in the steering box, but its pretty hard to get a hand down there. I'm assuming my steering gear is shot, and likely the cause of all my steering issues. (this would also explain the slop in the linkage, correct?) I will try to get at it to see if I can feel any clunking/slop when I put the alternator back in tomorrow. I have to get new linkage anyway (most likely from the JY) and will probably pick up a new steering gear (zj) More thoughts on this would be great. Trying to keep a positive attitude.... -Erin p.s.- I STILL need a horn surround. :thwak:
what I did not notice is a fresh looking wet spot near the steering gear box. I was just out there and stuck my hand under the gear box and it is wet. GRR. Could this actually be the cause of the play in the linkage? (the leak seems like a dead give away) I did not notice any noise coming from the gear box, but....One thing at a time I guess. Any thoughts on this would be great. My "mechanic" buddy is not so reliable these days..... -Erin
