Everything posted by hgeranium
B pillar courtesy light questions
hgeranium replied to hgeranium's topic in MJ Tech: Modification and Repairs
Good to know; so there's just no off switch? -
That makes me feel better about them in that case. I would just miss the OEM chrome bezel, but I guess I can DIYify the Euramtecs.. Thank you, Pete! -
6418 I believe -
Would you be willing to part with it? If so, how much? I might as well start collecting them now.
It always hurts to see an MJ in that state. I hope that it was given a good life before and is helping plenty of MJ owners with its parts.
Exactly what I needed! Thank you once again -
Just a few questions about the B pillar courtesy lights that I'll just throw into one thread. 1. How do the assemblies come apart from the B Pillar? Do they just pull/pry out with enough force or does the trim need to come off? 1a. How does the lens itself detach from the assembly? My driver side light works but sometimes needs to be jiggled into the right position to turn on. I want to be able to safely take out the lens to clean the contact points and swap an LED without breaking anything. 2. I have my driver side light in working condition, but my passenger side has the assembly in the pillar, but no lens at all. Are the lenses something that can even be sourced and replaced? Or are the lenses a part of the assembly? I have the Euramtec part # so if I need to replace both sides to keep them matching, so be it, but I'd like to keep the OEM parts if possible.
20 year bump incoming
05 PowWow at The Badlands...
hgeranium replied to Pete M's topic in Adventure Planning / Regional Groups
Great pics! And happy 20 years to this specific reply :p -
Yeah I’ve seen the all black caps floating around on eBay too. Definitely let me know the verdict whenever you have time. Thanks!
Wow these are expensive! I’m seeing between $20-30 PER CAP, all ranging wildly in condition. If anyone has some spares and is willing to part with them for cheaper, send me a PM. I at least need 3, but a full set matching in wear would be even better. I’ve read about custom/3D printed caps being made in the past, so if someone has that going on I am interested.
That’s great! Will help a lot when browsing eBay. Thank you very much.
Any leads on this style center cap? All I’ve been able to find on eBay are the all black but none with the black with white Jeep lettering.
Steering wheel doesn’t return to center
It doesn’t move at all. I can keep it turning in circles without holding the wheel. Stock control arms, stock everything. The fact that it occurred after the outer end makes me think that it has to be related to that tie rod end. -
The former. The wheel stays in place after turning and I have to manually spin it back. -
Removing old heater/ac vac lines
Ah, so the line goes much further into the dash than just a few inches into the firewall that I originally thought? -
I wish I had the answer. The shop I got it done at didn’t tell me nor noted it on the invoice. I could try to ask but am not sure if they kept a record. It was a reputable local shop, not Firestone or any big chains FWIW. -
I noticed that my wheel no longer returns to center after replacing the left outer tie rod. Stayed the same after the inner tie rods, drag link, and track bar were subsequently replaced (on different days- didn’t have time to do it all at once) and with the alignment done. The truck is aligned and drives great but the fact that it occurred after replacing the left outer end and hasn’t resolved after all linkage was replaced and aligned is a bit concerning. I understand this is likely a caster issue but not much other than that.
So you would just put a slightly larger hose on the broken side and attach the canister lines to that “sleeve”? Thinking about it, I feel like worst case scenario I can get out as much old line as I can from the hole going to the dash and stick a fresh line in there. I figure I can clear enough room by hand to get adequate vacuum for the HVAC. -
The two vacuum lines that go from the vacuum canister to the firewall for the heat/ac controls are so old and crumbly. The way that they're attached is not very secure and they frequently come off/break more when tinkering in that side of the engine bay. In regards to replacing them, are they supposed to just pull out of those holes going into the firewall side? I've tried removing them but that just leads to breaking the hose off at the spot that I'm pulling them from. I don't want to get it so short that I can no longer get the old hoses off or reattach them to the canister side so I'm curious about any tips on removing them. The heater side line is especially sensitive; it has no flex and crumbles into dust when I try to remove it. I think the heater side is a different material (plastic?) line, so I'm also wondering if I need to put another plastic line or I can just replace it with rubber.
Cool! PM me whenever you decide to come up. It would be nice to meet another CC member
I have yet another idle issue, maybe the same cause as my other idle problems, but with new symptoms. I’ll try to keep it concise So, this has happened three times in the last week. It starts off that the trucks idle sound changes as I slow down at a light, the idle is pretty rough and much lower than it should be (between 500-600, while park/neutral idle is ~750). The first time the idle crept so low it just died. Turned the truck on and it drove fine on the way home. The 2nd and 3rd time, I noticed the idle was off while at a light, and as soon as I took my foot off the brake, it died. Started right back up both times, idle fixed. After the 2nd time I switched back to my old IACV yesterday since I replaced it a few weeks ago, but the 3rd occurrence just happened 10 minutes ago, so that didn’t fix it. I have an inkling that it’s an IACV and my old one+new one are both bad, because my idle in park and neutral are fine. When I knew the truck was going to die, I could put it in neutral and the idle returned to normal, then back to drive and it went back down. Am I missing something else or should I get another IACV? All vacuum lines are good, cleaned TB and new TB gasket, manifold bolts tightened (still need to replace gasket), TPS set correctly. I feel like it has to be the IACV since it’s an idle issue only seen in a driving gear that fixes upon startup, so it may be sticking?
Voltage gauge inaccurate for anyone else?
Thank yall so much! I feel like that should’ve been the first thing I checked lol. The fix seems simple enough. -
I’m pretty sure this is a common thing but was just wondering if there were any possible fixes. With a multimeter, I’m getting 14.3 V at idle with no accessories and with AC and lights on, it’s at 14.1. While the gauge reads ~13.8v and ~12v respectively. It’s just annoying never being able to trust it, especially if my alternator were to start going out, which has happened before.
