Everything posted by jbhill
yea wood was all they had, so eh y not. plus itll be easier to paint(no grain to get rid of )
i still gota finish the steering column bracket and firewall/floor pan BUT the stock cluster will fit w/ minor modification :D
replacement panels usually only go to the factory seam.
haha true, the "trail rig" is my daily to so it doesnt get beat on that much off road. 02 fx4 ranger. manaul tcase, 4.0 5 speed w / 4.10 front and rear w/ ls in both :D
its actually a frame from an s10 :D lets see, droppin the cab down on the frame cab on the frame rear frame rails.
got my dash in today! bolted up like factory almost. had to drill new holes on the top by the windshield but thats it! pics will be up tontie.
i mite be there on sunday, gota lota work to do this weekend tho. i know all the guys that work at the 4wheel parts in marietta so yea ill hopefully be there:D
i thought i had it all figured out! (2wd to 4wd)
jbhill replied to Weezel's topic in MJ Tech: Modification and Repairs
yea i was about to say, y not just buy new lines... -
get some pbblaster soak them. also make sure you invest in some line wrenchs so you won't strip it and have to use visegrips... -
autometer gauges in the stock location
jbhill replied to jbhill's topic in MJ Tech: Modification and Repairs
not running any factory wiring so i don't wana try to get em to work right w/ a GM motor and painless harness. plus theyll be more accurate. and cooler lookin :D some small 3 in gagues should fit for hte speedo and tach. some 1 7/8 for the other 4 tho. -
pb blaster. spray it real good and let it set for about 5/10 min.line on the caliper or on the truck? -
corvette summer gone in 60 seconds(orginal) bullit hollywood nights(kinda sux) american graffitti
I'm wanting ot put the gauges behind the stock bezel, keeping it looking factory :D -
koo I'm gona get out the ole summite catalog at work tomm and chekc diameters and prices :D -
anyone done this to an xj or mj cluster? i took my cluster apart today and got the idea to run auto meter gauges in it behind the factory plastic cover n such. I'm just curious if anyone else had this idea.
eh i only gave like 45 bux shippped for that piece, tis new. i shoulda got the lower panel to sincei think the RHD one is diff than the LHD :doh: o well, ill make one if i got to. i can't wait for it tho, i relocated the hood release to the right side tonite, looks factory :D i wanted just a plain one since I'm prob gona paint it anyways.
I'm sure they did, they put 8.8s in almost everything. rangers(90 up 4.0,02 up 3.0) explorer/sport tracs(all years)/mustang(v8 including cobra irs will work)/tbird-cougar(supercoupe and v8)/f150(v6,not sure on year,some base model 4.6s maybe)/new explorer irs 8.8 ring and pinion will work also.....
4wd MJ leafs vs. 2wd MJ leafs vs. Explorer leafs
jbhill replied to Pete M's topic in MJ Tech: Modification and Repairs
explorer leafs are SOA and rangers are SUA, but you could just flip the center pin, no biggy. FYI b4 you pull them out, mark the front and rear. i could be wrong, but the pin i don't think is quite in the direct center of hte leafs(plus there wouldnt be any headache i would assume). explorer 4 door leafs will definatly be stiffer then ranger leafs(i had explorer leafs and rear end in my old 92 ranger), depending on what ranger you look at(std cab, motor size etc) will determine spring rate. also towing package and 4x4. i would look for 4x4 explorer leafs from a AWD or v8 explorer/mountaineer w/ towing package. i would assume those would be the stiffest if stiffness is what your looking for. or just feed em some viagra :D -
found me a dash bezel to :D
ok i just paid 96 bux shipped for this new OEM RHD dash shell. all i need now is the bezel, maybe the cluster:D if i can't find a bezel, ill modify my LHD bezel to work :D I'm prob gona run some autometer gauges or sumthin. from http://discountjeepparts.com
Lets see pictures of your rust bed skin repairs.
jbhill replied to 89MJComanche's topic in MJ Tech: Modification and Repairs
mine is rust free :D -
sweeet. all i need is the dash,bezel, and cluster :D i did find a new OEM dash for 80 bux on jeepparts.com or sumthing like that, they just don't have the instruement bezel.
i would use atleast 1/8th wall cuz the stock rails are 14gauge if I'm not mistaken.
also dumping freon into hte atmosphere and not recovering it is ILLEGAL as hell. also take the belt off, idler pulley, and the lines once pressure is recovered, the a/c comp is only 2 bolts and 2 nuts, 14mm i believe :D
