Everything posted by mj Mike
Soon they will be taking care of you! :shake:
congratulations to you & your Daughter! :clapping: you just reminded me, my youngest sister is graduating from high school tomorrow in Reno Nevada & i can't make it. :( she really wanted me their! & she is going to be pissed :thwak:
Eagle spell it out in this post, toward the end: viewtopic.php?f=2&t=22773&p=235043&hilit=bolt+proportioning+block#p235043
i ordered some more poly track bar bushings. MOOG Part # K3176 now that i know about the stock undersized T/B bolt, i will fix it on all my jeeps drilled them up to 1/2 :clapping:
thanks, I went today & got 1/2 grade 8 bolts w/ nylon lock nuts & got it bolted backup ;) & i got my poly trans mount today :brows:
thanks for the good feed back & great suggestion on the motor mounts !!! i still have front end noise! I checked the track bar & noticed play in the axle side. the bolt is tight but the track bar still has play. I removed the track bar & noticed the stock bolt (3/8) is way to small for the hole in the axle! :doh: It fits the sleeve in the rubber bushing on the TNT track bar. Is hardened so i can't drill it out. So i burned out the rubber bushing! I have A spar track bar with a poly bushing . i used the poly bushing with a 7/16 bolt & it still is not a tight fit in the hole on the axle side. looks like i am gona drill it up to 1/2 (3/8) (7/16)
How do you do a SOA for Dann 44
mj Mike replied to littlezeeker's topic in MJ Tech: Modification and Repairs
A pic of my TNT U bolt eliminators & a pic of a friends RuffStuff's setup -
XJ interior seats work in MJ ?
mj Mike replied to 2brandonb's topic in MJ Tech: Modification and Repairs
:agree: easy & worth while! DIY: how to=http://www.comancheclub.com/forums/viewtopic.php?f=9&t=8093 -
it will boost up the rear about 4'' to 5'' depending on the height of the leaf perch. i run a D44 with 1 1/2 u bolt eliminators it sits about 5'' with out the shackle http://www.tntcustoms.com/u-bolteliminiators.aspx or if you don't like the idea of u bolt eliminators. RuffStuff makes Quality leaf perches & beefy 5/8! U bolts http://www.ruffstuffspecialties.com/catalog/D44SS.html -
Control Arm Replacement - jack question
mj Mike replied to tbrand's topic in MJ Tech: Modification and Repairs
Ideally you don't want the axle to be at full droop. You just want to support the axle a little, without compressing the coils. Its not coil over's, they are Fox 2.5 by 10inch Bypass Shocks, and Fox Bumps with Deaver Coils. If you are interested, check out page 4 of my build thread, link is at the bottom of post. -
osama ''Game over'' t shirt http://6dollarshirts.com/t-shirts/Osama-Bin-Laden-Game-Over-p-11449.html
:bowdown: that is what i am looking for! A trans mount that will perform well off road & is firm. i don't like all that motor & trans movement. i hear if you swap one mount to poly (motor or trans) you need to swap all to poly. no mixing rubber & poly mounts? is this the mount that you run? http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=1468
Yes Keep your jack stands under the the Frame rails, between the LCA mount & the trans cross member. Do not place them further back then the trans cross member! My long arm brackets force my jack stands Back to the cross member, but you can see that you can put them much further forward towards the stock LCA mounts , this macks the truck much more sturdy -
Lots of noises in the front end! the only things that is still stock on the front Axle, are the unit baring hubs & the Axle shafts I R&R the new hubs today. Remove Reinstall
so you are saying there is more vibration at idle? How do they run off road?
:agree: X 3 Thanks!
Any budy run poly motor & trans mounts? how much firmer is it than rubber mounts?
I've got some bed engine movement / vibration. I'm going to swap to polyurethane motor mounts & poly trans mount.
