H8PVMT
Everything posted by H8PVMT
  1. I need two band clamps to put exhaust back together, one will go where the flange connects the down pipe to the cat, the other after the muffler, have to order and install by Wed so want to get it right 2.25?
  2. If its a 5 son the master might have leaked on the fuse panel, my passenger side turn signal is frozen on
  3. I just did my whole system two days ago, real straight forward, just a pain to get the through bolt on reinstalling the master Got the whole system next day for under 200on Amazon
  4. Mine is sitting on a workbench and there is very little movement
  5. Grabbed a bunch of both, thanks
  6. left the piece I was going to bring to the store at home, can someone tell me the size for the rubber lines that come out of the tank to the fuel filter? thanks doug
  7. I appreciate the offer but the bracket inside the gate is shot so unfortunately wouldn't do me much good How come most answers to jeep problems include prying with screwdrivers?
  8. Trying to take the cheap route I was going to pry the tranny out of reverse with a screwdriver through the reverse light hole but then came upon this issue so with no way to bleed the system out came the tranny loosened up the shifter seat and the back half of the case and it came loose, got the new clutch and slave in yesterday so hope to have it moving soon, just need to get the new fuel pump to fire up broke 6 different harbor freight tools in the process and each time my 15 year old craftsman tools did it with ease, hoooooray china
  9. bought an mj and the handle on the tailgate isn't present, and it's stuck closed, any tricks on getting it opened? thanks doug
  10. How did he pinch off a hard line
  11. Front doors forward will work
  12. Mine is a Bosch universal fit, Part number for 6 cyl matches up
  13. The diamond plated MJ? Either way, guy hasn't responded to emails
  14. Pulled my sending unit since it wouldn't come on and the hard lines are about shot but found this when comparing it to the new one It fits perfectly in the new (used) unit I got and everything lines up Triple checked numbers and they are the right parts Any ideas? 89 6cyl long bed
  15. Join your local club wherever you live, most guys are more than willing to stop by and help out for pizza/beer.....I know I would Get your shaft the right size for 4x4, then its about 400 bucks and a few hours to do the whole thing. You might think you can't do it but if you have a jack and a set of wrenches you can do it easily I suck at wrenching honestly but still accomplished two engine swaps and axle swaps
  16. I thought the jk front 44's were basically a Dana 30
  17. Manual says to get a new washer or use rtv on it
  18. I got my mc off Amazon for20 bucks, only takes 5 mins to swap it, I've read a lot about slave cylinders being crap right out the door also
  19. Probably not your issue but I know you have to put a New diameter pilot bearing when changing from 2wd to 4wd, might be worth googling that route for a ba/ax15 swap
  20. First 5 speed? :cheers:
  21. Thought I read somewhere you can not resurface them, putting a new clutch in and want to get everything at once while I'm in there Infos in the sig Doug
  22. My old xj was 3.07 with 31s, never has a problem off the line
  23. Fill the mc if empty and pump the clutch, if your foot gets wet its the master, if your tranny leaks its slave
  24. I just picked up the line on Amazon for 18 bucks, most places wanted 60 See if your mats look like this Mc was empty, filled it up and pressed clutch and soaked my sock in dot3 Only headlights and buzzer work on mine, panel is so bad best fuse I pulled was only in three pieces
  25. Unless previously changed they were all internal until 93 Nice find
