H8PVMT
    west redding, ct
  • Interests
    Anything but golf
H8PVMT's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I need two band clamps to put exhaust back together, one will go where the flange connects the down pipe to the cat, the other after the muffler, have to order and install by Wed so want to get it right 2.25?
  2. If its a 5 son the master might have leaked on the fuse panel, my passenger side turn signal is frozen on
  3. I just did my whole system two days ago, real straight forward, just a pain to get the through bolt on reinstalling the master Got the whole system next day for under 200on Amazon
  4. Mine is sitting on a workbench and there is very little movement
  5. Grabbed a bunch of both, thanks
  6. left the piece I was going to bring to the store at home, can someone tell me the size for the rubber lines that come out of the tank to the fuel filter? thanks doug
  7. I appreciate the offer but the bracket inside the gate is shot so unfortunately wouldn't do me much good How come most answers to jeep problems include prying with screwdrivers?
  8. Trying to take the cheap route I was going to pry the tranny out of reverse with a screwdriver through the reverse light hole but then came upon this issue so with no way to bleed the system out came the tranny loosened up the shifter seat and the back half of the case and it came loose, got the new clutch and slave in yesterday so hope to have it moving soon, just need to get the new fuel pump to fire up broke 6 different harbor freight tools in the process and each time my 15 year old craftsman tools did it with ease, hoooooray china
  9. bought an mj and the handle on the tailgate isn't present, and it's stuck closed, any tricks on getting it opened? thanks doug
  10. How did he pinch off a hard line
  11. Front doors forward will work
  12. Mine is a Bosch universal fit, Part number for 6 cyl matches up
  13. The diamond plated MJ? Either way, guy hasn't responded to emails
  14. Pulled my sending unit since it wouldn't come on and the hard lines are about shot but found this when comparing it to the new one It fits perfectly in the new (used) unit I got and everything lines up Triple checked numbers and they are the right parts Any ideas? 89 6cyl long bed
  15. Join your local club wherever you live, most guys are more than willing to stop by and help out for pizza/beer.....I know I would Get your shaft the right size for 4x4, then its about 400 bucks and a few hours to do the whole thing. You might think you can't do it but if you have a jack and a set of wrenches you can do it easily I suck at wrenching honestly but still accomplished two engine swaps and axle swaps
