comanche12
Everything posted by comanche12
  1. great mj ands sorry to bring it up. i would suggest u to heatstrink those radio wires to replace those electric tape. trust me you will love heat shrink over electrictapes after fix the bugs :thumbsup:
  2. Ok to start with draining the fluids. How do I drain the tranny, rear diff, and brakes? And what should I use to replace the fluids. I have an auto tranny with the 2.8L v6 2wd. My rear end is an AMC 20 as far as I know my brakes are stock dot3 for brakes fluid rear 75w-90 but use 75w-140 if your doing overhaul often i don't know about fluid for auto tranny? :dunno: maybe ATF?
  3. can't even loosen the bleeder screw, its been seize and strip. i decided to buy new calipers. only 14.99 each from oreilly :banana: i don't want to take risk to drill and tap the bleeder screw :(
  4. make sure flush everything to have a good tune up. my jeep have BLACK brake fluid right now. lucky i just find it out by today. I'm gonna flush it out tomorrow
  5. installed tierods and brake hoses for front brakes. havent do the rear yet until after get new rear brakes for my 9" rear :thumbsup:
  6. finally got my new extended brake hoses and tierods from ups. installed them today. Pictures will come up later.
  7. peeked at outside front door and saw my big presents from ups! :banana: its extended brake hoses and new tierods!
  8. ordered new tierods for my front hp d44 my brakelines havent shipped yet from quadtrec :( damn vendor
  9. i was thinking about how to make two brackets on my front bumper for my foglights my foglights so i have a idea! :idea: i measure and make a teaser with foglight on bumper then mark the location up teaser protype steel plate welded it up and make sure foglights seat balance in the under bar "stinger" stiffen the plate up to prevent shaken like during drive with rough road video of compare how its stiffen up :thumbsup: decided to add one more plate for mroe stiffen and its actually more stiffen up :thumbsup: I'm pretty done for the night. its get late and very cold outside.
  10. other idea to be creative :idea: i was thinkking how to make bracket for my foglight and where location so i made two brackets. will paint it up soon and adjust the foglights more more info about it in my project
  11. haha now I'm mood to watch back to future I to III now!
  12. just let you guys know that i got my blower work by replaced the motor and new 12 gauges of wire for power from fuse to switch. all i need to replace later is resistor and climate control dash board because previous owner cut the vent for windshield defrost :doh:
  13. :idea: i have a idea to do the temporary fix my windshield vent to try find a way to ram the air into vent by use the card board that i have lay around in garage its just appear my head when i was electric taped my wires :thumbsup: before after
  14. no actually ferrari r actually faster than any sti expect if modification like stage 2:thumbsup: I'm still pissed at ken block :( and i hear that travis r transfered to nascar????? :nuts: i love all sti since its still a impreza to me. period yeah what was ken thinking! and I know theyre top speed is faster but the stis can keep up on tracks which is just awesome anyway and travis is trying out every sport that deals with a motor and wheels true but i still rather kens sti over kens pos ford fiesta :thumbsup:
  15. no actually ferrari r actually faster than any sti expect if modification like stage 2:thumbsup: I'm still pissed at ken block :( and i hear that travis r transfered to nascar????? :nuts: i love all sti since its still a impreza to me. period
  16. working on heater system now. stupid weird electric bugs play around with me :ack: edit: finally got blower works. replaced blower motor and new wires from fuse to switch. only need to replace are resistor and the whole climate control dashboard since the vent tube was trimmed for give space to radio. :nuts: :fs1: I'm so sick of previous owner for what he did to my mj :headpop: i hope my heater will able to defrost the window with trimmed climate control dashboard soon I'm gonna put dashboard parts back together after my hands thaw up from frost bite
  17. good enough to buy me new shocks for front that i damaged it anwhile ago
  18. thats what I'm thinking :idea: how many should i sell for it.
  19. removed my blower motor last night and retest and try put oil in it as other thread recommend to. now its spinning fine :nuts: while removed it out. guess what i found a box that bolted on the plate that support coolant expand bottle? :yes: but its didnt hook anything and just sit there cover with mud :no:
  20. thats what i though, its correct bulb with two metal tab on bottom. both those two bulbs r different than back up lamp bulb i checked the condition of the socket. its been cover with anti corrosion grease but it look like brown as mud though. ill check it again and check the connector too. probably the trailer harness can be cause since its been hacked and didnt complete yet as i noticed
  21. its removed like charm thanks for advice :thumbsup:
  22. ah didnt think about that! thanks!!! :thumbsup:
  23. found it and the result is that i knew it that blower is dead. won't even blowing after apply the volt. but seem need small hand to able reach all those three bolts. :ack:
  24. thanks! hopefully ill find it as piece of cake
