Everything posted by CoastChief
I was looking through my notes after I saw that my coolant looked like river water. I had taken it to be replaced it the week I had purchased her. I showed a few members and they all mentioned the possibility of a HEAD GASKET LEAK? So I did a flush, flushed out the hoses top and bottom. Used 3 gallons of distilled to flush again. Ran for a second, flushed again. Filled with coolant and water. When I looked into the bucket I found oil contaminated in the coolant. looks like I’ll be doing some reading. any tips, advice as always is deeply appreciated!
August 2020-CoastChief’s 1988-White Rabbit
CoastChief replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Thank you all. Iv hope to work to keep her in great shape. @eaglescout526 Thank you especially for all the help, and patience! -
It was super simple, it took 6 hours it was a demo test. My friend is using it for model making in architecture. It can print complex parts pretty fast. We used YT and figured how to make files and everything.
awesome guys! keep em coming! I never put where I was from! Orange, CA.
I think remember us starting a thread on this for pop culture Comanches. Here are some Iv found so far. Cobra- Regular Show- ones I can remember people mentioning - karate kid, Monsters Ball.
88 4.0 White Rabbit - CA
CoastChief replied to CoastChief's topic in Member Projects: Your Comanches
Swapped out the old fender liners for new ones. Spent most of the time fighting the non OEM plastic to line up with most 6/8 push pin holes. The two top ones would not fit, but Ill take a heat gun and work them along the wheel well. Drill a new hole into the liner. Broke one of the mounting nuts clean off not paying attention. Guess that’s what I get for rushing through. I knew it was going to happen, could feel the socket heating up from the metal twisting. overall I’m happy with the fit of these, found a random cap that fell into the door space. Couldn’t find what it covered. -
Just getting an idea of who is in California. - Michael
91 Eliminator 83K miles refresh with NOS parts
CoastChief replied to Red Mistress's topic in Member Projects: Your Comanches
wow this is amazing...everything is so sharp. -
Thank you guys! -
love these! thank you! His videos are great! -
thank you Jason, I figured id just replace the whole thing. -
SIX MONTHS OF OWNERSHIP PROBLEMS/QUESTIONS/COSTS PROBLEMS AND ISSUES (This is a log for myself and for others that just may be interested in what the cost of ownership from a novice perspective is. Along with notes on some issues iv had, and if they've been solved) VACUUM LEAK - at above 2300 rpms the air cuts off. Corrected itself once by making the same noise an airplane toilet makes at times. ( Loud pressure followed by immediate shut.) POWER STEERING SOUND IN TIGHT TURNS - when turning at low speeds it makes a weird noise, sounds like its struggling) SPEEDOMETER BOUNCE- Replaced with new speedocable WARPED AIR BOX- Warped and damaged airbox - Replaced with used airbox MAINTENANCE - 137, 878 STARTING - VALVOLINE - 138,232 SELF - 144,368 WIX and CHEVRON DELO LEAKING WIPER BOTTLE - leaks wiper fluid along the inside wheel well, could be cracked hose or bottle. LEAKING COOLANT HOSES - light leaks from coolant hoses. coolant is rust colored in some areas. ( note shine ) LEAK - slight oil leak under engine area from transmission SECURITY - worried about it being stolen. kill switch> Zip ties on tale gate>Slight tint? DOOR HOLES/ NEW MIRRORS - Bondo, sandpaper, paint type?? Recommendations? SEM primer/ ? REPAINT CAMPER - Yellowing camper made from a rigid plastic. ( Bac-Pac ) FIX MAP LIGHTS - sometimes works RECOMMENDED FLUIDS - What fluids do you recommend for a Southern California Jeep - can you do them all relatively easy? Do not want to mess anything up. so far I'm using chevron delo based off hornbroads notes. CAR HEALTH - how do you check your engines health? Oil iron content? Compression tests? When do people rebuild 4.0s? What should I look for to keep my truck mechanically and electronically sound. SLIGHT SURFACE RUST ( UNDERCARRIAGE ) - best treatments? Wire brush? Sandpaper? paint? CAMPER SHELL REPAIR -. Leaking gasket against cab, cracking rubber in small areas. want to waterproof entire truck. Bule tape? new camper shell gasket? looks very simple. AUTO CARE ACCESSORIES - What are some things you recommend I upgrade or change on the Comanche to help ensure it stays in good shape> covers > dashcovers> wheel cleaner>tire shine> NO START RANDOMLY - short trips usually - Stronger starters? Starter tested good, Battery tested at 12v, poor solonoid? starts on hammer wack. RECOMMENDED TOOLS ? - tools to have around that would be useful - soldering iron - voltage meter ? PERIOD UPGRADE PACKAGE - how do fellow Comanches feel about changing the sticker package. To a higher end package, love the pioneer decals, and others. CLIPS, SIZE CHART? SMALL HARDWARE, ORDER ONLY? UNCOMMON? What size are common hardware, what is uncommon hardware? Sizes for clips and basic hardware>? ON HAND- What do you guys carry with you for / roadside REPLACE - Should I look to replace all the old bushings on the Comanche all around? MIRROR REPLACEMENT - Mirror replacements with stock black. will paint chrome ones. RE-Dye headliner - are there sprayable dyes? or has anyone found the correct liner to re-dye roof liner. FIX MAP LIGHTS - need a voltage meter REAR VIEW MIRROR REPLACEMENT - rearview mirror starting to shake aggressively RECOMMENDED SOUND UPGRADES? OVERALL RECOMMENDATIONS? COSTS (includes tools and minor expenses/ rounded numbers.) Jeep Comanche Cluster - 50.00 New caps / hoses - 30.00 Solution finish trim restorer - 20.00 Dremel steel brushes - $7.00 Turbo towels - 12.00 GB ox guard - 4.00 TU108 temp gadge - 20.00 PS133 Oil Pressure- 21.50 3mm nitrile gloves - 7.00 4in magnetic key holder x2pac - 2.00 4in magnetic parts tray - 3.00 Chilton repair manual - 4.00 Jeep Rx173 radio- 35.00 Tracker Marine Courtesy Lights X2 - 35.00 ECU 90’ - 56.00 Sentinel light relay - 5.00 Jeep Rx171 Radio- 15.00 Under Hood lamp- 20.00 Mothers polish - 8.00 EZ clamps for wobbly mirrors - 4.00 CA-3068 Speedometer cable - 36.00 Door body molding - 20.00 WD-40 3x mini pack - 10.00 CRC OD electronic cleaner -5.00 Lithium Greese- 5.00 Paracord - 5.00 Bolts for brushguard - 13.00 Bucket with dirt catch - 5.00 Roadside compressor - 40.00 16oz Fix-a-flat - 7.50 Anti-Freeze- 11.00 Warn Brushguard- 45.00 SEM primer - 20.00 Powder Coat - 50.00 Turbines - $325.00 1/4th Extending ratchet - 15.00 3M tape -10.00 CR Laurence ED700S Duo Vent rear window - 180.00 Airbox with K&N filter - 25.00 Rear wall plastic trim - 15.00 Wheel Caps (nos) - 15.00 Tokico Trek Master Shocks (stock ride height) - 150.00 Interior tool Kit W/Caps - 14.00 2x H4 Wiring Harness kit - 20.00 6in wrench Extension 3/8ths drive- A/C Parts compressor/ heaterbox/ - 230.00 Front Fender liners R&L - 70.00 Chevron Delo 400SDE 15w40 CK-4 - 29.00 WIX 51626 - 9.00 Chemical Guys Citrus wash - 9.00 TOTAL 07/28/20 - $1748.00 -
Man, that walleye is a monster
100% like ironically @Money_Pits mentioned. 30k base. The two door looks really good IMO. If I had to choose a new Jeep or this. I’d probably go with the ford over fiat. Suzuki Jimny is Badass for the price. Although Toyota’s prices are getting higher, and higher. Almost the same as a Land Rover. Toyota have a long-standing record for being reliable, good, easy to maintain investments. Japan has been doing a lot right. the legendary Toyota J70s...... I would make payments on one. Even come with an optional turbo diesel V8....I used to see these everywhere in colombia and southern Mexico. The new bronco looks really good though. I’m happy to see more outdoorsy/ adventure type cars being made. Hopefully it keeps the snowball of 4x4/ overland rolling.
My brother has a 2017 mustang, leased a Fusion, my sister has an the gigantic Expo. I have to pick them up from the dealership constantly. Were you have to argue for your warranty, to still be service charged out the @$$. I would never invest in a newer " Jeep ". Not only because of cost, but they have recalls on things like cylinder heads, Airbag software, catching fire, ignition switches, Fuel tank,inadvertent airbag deployment, steering software may disable the stability control, alternator..............The list is extensive. Many of the parts are critical or potentially life threatening. Iv had a airbag go off when I was hit, seared all my hair, 2nd degree burns and no use of my hands for months. Outside of the already likely mechanical/ software failures. Your airbag could Mike Tyson you randomly. ... Ford is in really bad shape financially. My brothers mustang with close examination shows were/ how they are making their money back. Fords strategy seems to be targeting the " sports " enthusiasts. People that do not mind spending money on ridiculously priced packages/ parts. ( GT, Ford Raptor, Etc ). Where they can make good money on the mark ups. I admire them for not taking the bailout, but they fired everyone from there factories. Although still primarily made in the USA,CAN I cannot say they have not earned my confidence.
Had helped the original owner move some stuff around in the garage yesterday. His grandkids, and family all moved to Texas to flee our state’s growing tax burden. Figure it wouldn’t be too much of a hassle. While we were organizing he found his old Jeep box. Got the original window sticker along with some old receipts. In addition Instructions on how he converted the radiator to a 92. Straps roof rack for a kayak/ canoe. Very lucky to have a very organized first owner. A Korean War veteran, served after the war at Redstone - Huntsville, Alabama. Up until the late 70s. His wife and him have been together for 62 years. They are about as old school American as it gets. a little outside the conventional Jeep post, but I find the history of the car interesting. -
I just asked him, he said he had no idea. Were from a aftermarket truck stop -
Chrome Factory Step Bumper -- CA
CoastChief replied to Gjeep's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
omg man, this is nuts -
1990 Comanche Pioneer 4.0L 4x4
CoastChief replied to early comanche owner's topic in Member Projects: Your Comanches
you buy that yellow rubber wheel? my paints starting to dull and was gonna take mine off before getting the paint fixed. Love seeing the bright red paint under those decals! -
https://www.copart.com/lot/50902299?fbclid=IwAR3o7_cCiZJKmdhB2kO0E5DdDc9kWeBDdHH_-LE4dF7hFsO2Wv5dfD_VNIw
Comanche Dawn
CoastChief replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
this is so damn badass. amazing work! -
also @Gjeep thank you for the recommendations ! I just saw your comment! Really appreciate it! -
Seen a few really really nice camping set ups. Wanted to see if anyone was pulling a boat or had put a kayak on their Comanche? Recently was thinking of getting one but wanted to see what people thought about the investment. Getting into Fly fishing, and just being able to get away from the city relax in the Jeep. love to see what you guys are up too! Here’s two bass I caught earlier this week. one on a small baby bass with booted tail. second on dead sticked slow retrieve a wide lip crank bait. and a fancy salamander that walked up to me in Batcave, NC
Defiantly are some genuinely kind people. He sent me a email not to long ago. Answering some of my questions in more detail. Yes! He would hall a small blue trailer. here it is on there last trip together. - always been big on fishing but he showed me his old Hobie fishing kayak. Mentioned that’s what the racks were for. Defiantly got me curious about taking one out.
