JimiGibbs
Everything posted by JimiGibbs
  1. It was on a hard dry surface so maybe it is normal.... I just don't remember it from before. Going to play with it some more tomorrow. THANKS ALL
  2. Thanks... but I think it should (and did if I remember correctly) turn more smoothly. It really hops.
  3. Been a while since I have used 4WD.... Actually been a while since I have done anything with my truck. Put in 4WDHigh and when I turn either way it jumps and has a very wide turning radius. I assume it may be something in the front differential (both wheels not turning the same) but not sure. Any ideas??? THANKS
  4. THANKS..... I thought it was to good to be true. Jimi
  5. Anyone had any experience with this? Ad sounds to goo to be true for the price..... https://gainmpg.com/products/performance-chip-for-jeep-comanche?rq=yr_1989~mk_jeep~md_comanche~yg_4-0l Thanks, Jimi
  6. Pretty sure it's legit...... I think he had it for $400 a while back.
  7. Near me and very tempting..... But I don't need it. Hope it works out for someone. Jimi https://www.facebook.com/marketplace/item/312824674312624
  8. Very nice build.....
  9. That looks like it could be fun!!!!!!!
  10. I'll do that today..... THANKS Jimi
  11. Finally got it out..... May loosen the bolts to get it back in. Anyone have any ideas on the ground wire????
  12. When I was removing the lower bezel to replace my headlight switch the piece below was on the lower screw (shown) on the driver's side. Looks like a ground but I don't see any other wires that are not connected. Any ideas where / if it belongs? Also, how do you get the instrument bezel off? I've seen posts on here that say just "gently" work it out but I am having no luck and don't want to break it..... I've tried top first, bottom first, sideways, etc. Steering column is in the way. Thanks, Jimi
  13. Very nice..... Great history.
  14. Nice..... WELCOME
  15. Nice...... Let the fun begin!!!!!
  16. That color is beautiful..... Going to be a great looking truck.
  17. Yes PLEASE!!!
  18. Yes.... It does have trailer wiring. I've never used it or checked it out. Guess I need to.....
  19. They work fine without the headlights on...... so I'm thinking headlight switch but maybe it's the signal switch.
  20. The sockets are all factory and in very good condition....... I'll pull them out again and do some checking. THANKS
  21. I have upgraded all my exterior lights (except headlights) to LED. With help on here I changed the flashers and have working LED turn signals...... EXCEPT when my headlights are on. Then both tail lights blink together. Also when I turn my headlights on my non original radio comes on. I have done the KS Harness upgrade. Not sure how the previous owner wired the radio. That's next to check..... Is it possible I have a bad headlight switch? Or is there something else I need to check? I don't think grounding is an issue but I will keep checking. THANKS in advance for any help. Jimi
  22. So sorry..... Man I hope you find her.
