nitroxsteve
Everything posted by nitroxsteve
Its not that heavy. once I had a flat tire while hauling a load of firewood. So I just unbolted the bed and carried it and the cord of wood home on my back. Then I loaded my air compressor and tire machine in the bed and carried it back to the truck to repair the tire.
I found the breaker in the fuse box was corroded and would cause the wipers to stop working. Try wiggling the breaker while the wipers are on and see if they try to move.
I think XJ leafs are shorter..?
He may be an idiot for letting the good ole boy near his vehicle in the first place... Why are you so down on good ole boy's ? some people on here my find that insulting.
If there is much gas in the oil it will ruin your bearings. I would change the oil soon.
Wanted Door Lock set with Keys (found them thanks)
nitroxsteve replied to nitroxsteve's topic in Wanted
Wondering why it has that it only fits 84 XJ's: Fits these Vehicles 1984 Jeep Cherokee (XJ) 76-83 Jeep CJ-5 76-84 Jeep CJ-7 81-84 Jeep CJ-8 Could there have been a change after 84? :cheers: I'm not sure why its listed that way. I think they are all the same untill they switch to the single Chrysler key that works both doors and ignition (I don't know what year that is). -
Thanks Thats what I'm looking for. -
I'm in need of a set of Door locks with keys. Parts stores all sell the wrong ones. Thanks,
I thought you had more leverage with the cable fully unspooled (keeping the proper amount cable on the drum of course). Thats the first wrap of cable.
Valve cover question
nitroxsteve replied to nitroxsteve's topic in MJ Tech: Modification and Repairs
My air box is all bent out of shape (I think the oil screwed it up) Does any one know if all of the air box's the same for 4.0. I'm going to try to find a valve cover and air box tomarrow. -
I have read about updating the valve cover to a newer style. Is this to help with the oil blowing into the air cleaner?
Hey, I took a look at that truck but it has a bed liner screwed in and the bed is now full of junk. I was not able to remove it. Sorry man.
Thats what was needing to know. I basicaly want to fill the stock hole.
What size speakers are a good fit for the door? don't mind cutting the interior panel but don't want to butcher the metal. Any pics would be great. Thanks
I spray dyed my tan sun visors grey and worked great.
installing used gears
nitroxsteve replied to trail grenade's topic in MJ Tech: Modification and Repairs
You will see the original wear pattern on both the pinion and ring gear. Be sure to use contact paint and set it up so you see a similar contact pattern. Should not be any problem. -
Ill check it out this weekend
I'm going to the pull a part this weekend and may be able to get you one from that truck. Let me know if you want me to check it out for you.
best place to buy carpet?
why not line it, then put vinyl down? rust proof, quieter, and a little comfort on long drives... Thats what I plan to do. Clean up the small areas of surface rust, bed line it, and install the vinyl matt. -
ordered new vinyl floor matt today I'll give a report on the fit after I have time to install next week. -
wanted: header panel(grill support)NC found one thanks
Thanks, I went and got the seat from the pull a part today, ($35.00) it was actualy in great shape. I took it to the car wash on the way home and cleaned it up.I also so pulled the park brake assembly off, mine was stripped out. My header panel is repairable just didnt want to fool with it, there is a good one on a cherokee at the pull a part I'll probably head back over this week and pull it off. -
How much? -
When I did a map quest for Hampton Roads VA it shows it in the middle of the Chesapeake Bay, do you live on a boat? I don't have any plans to be in that area soon, but I never know when my schedual will change. Thanks, -
I need a header panel for my"88" I also need a good bench seat any color is fine I plan to recover it. I'm in North Carolina but travel all over the east coast for work. Thanks,
Whats your opinion on the carpet vs the vinyl matt? I would like the vinyl matt better but thought it will be easyer to tell if i'm taking on water with the carpet. Seems like the the vinyl hides water under it.
