Appstate97
Everything posted by Appstate97
  1. I've searched and read a bit on the topic of the fuel rail not priming and I have a few questions. On friday my truck shut off. When trying to restart I noticed that I didn't hear the pump priming. I got the truck towed home and started researching. In Feb. 2017 I refreshed the grounds. Could the grounds need to be refreshed again? I was thinking about refreshing the dip stick ground due to oil build up. I've checked the volts on the fuel pump relay when the key was on and got 12v when grounded to batt and touched to 86. Ground to 30 got me 4.6v. Then I checked the orange (power?), gray (no clue), and black (ground) wires by the fuel tank I got 6.97v with the key on. I am trying to pin point the failure before spending a ton of money. Any help would be great.
  2. What bench seat cover do you have? Can you send a picture? The back of my bench seat is torn up and I've been looking for a cover similar to yours.
  3. Any suggestions for engine sludge? I've changed the oil and ran seafoam for about 100 miles. I'll change the oil again this weekend.
  4. Does anyone have the measurements of a bench seat? Height and width of bottom and top pieces. I am looking for a seat cover.
  5. I'll keep an eye out and hopefully find some for cheaper.
  6. Is he on NAXJA?
  7. Does anyone have a connection who is selling these injectors? Used is best due to my low budget build. I've looked on e b a y but am having trouble finding the 746's at #19. There's a ton of injectors that say they will fit but I like to follow the advice and grab 746's.
  8. Is there any way to repair back to stock? What are the pros and cons of locking the cad system? Is a posi-lock a solution?
  9. I was replacing my floor pans and cut threw the 4x4 vacuum lines on the passenger side. The lines look similar to brake lines but aren't. What are my options for repairing the vacuum lines?
  10. How did you make your headliner? I am looking to do something very similar. Currently, I have bare metal and no parts to assist in the reconstruction.
  11. What kind of radiator setup is that? I'm new to the Comanche game.
  12. Does anyone have the Sherman part number for full floor replacement pans? I've tried searching and pulled these numbers but want to make sure they're correct. Sherman full floor pan replacement: Left side: #075-46CL Right side: #075-46CR
  13. I just picked up a 87 Comanche 4x4. It has a 4.0 with auto tranny. I found some rust around the floor pan area and am in the process of cleaning it up. I am trying to figure out if I should buy floor pans or just make my own as I have in the past. After the floor plans are finished I am going to move on to replacing/rebuilding the seats and center console/bezel. Keep us up to date.
  14. Comanche Fanatic, Who around wake county would you recommend for a used head or to rebuild my current one? I've recently picked up a 1987 Comanche.
