Scooterlawson80
Scooterlawson80's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Valve cover just got done 2 weeks ago..dry as a bone all the way around it Sent from my iPhone using Tapatalk
  2. Ok guys..i got a 88 comanchd 4.0 and i have replaced the rear main 3 times less then 2 weeks...i kept thinking it was still it...i did everything just like i should..but now i noticed the oil is coming out from between the trans and dust cover..is there a seal behind the flywheel that could go bad? Sent from my iPhone using Tapatalk
  3. Dunno if u can tell but theres a lip back inside there..if i peck it that far in it will just fall down in it Sent from my iPhone using Tapatalk
  4. It seems like if it goes that far it will fall down into a little lip....???? Idk...when i pulled my trans the pilot bearing came out with it..so i guess last owner didnt putit in right....how can i post up a pic?
  5. Ohh yea..its a 88 comanche 4.0 with ba10 trans
  6. I'm in the process of putting in a new pilot bearing..I'm sitting here under the truck now lol..I'm needing to kno..how far do i peck it in? Just a little bit? Or untill it stops??? Needing to kno asap...thanks lol
  7. I am in the process of changing ny rear main seal this morning...i noticed my pickup tube looks a little dirty...is it possible to remove it and clean it and put it back in or do i have to buy a new one??
  8. Yes for now...and when and if i get a bed i will tackle the rear bulbs and sockets are good
  9. On the plug that hooks to the tail light plug..which one is ground? Theres a few black ones
