EUREKA
Everything posted by EUREKA
  1. They look great in purple! Lets see the plug wires.
  2. Glad it worked for you!
  3. Not for the HO 4.0 though, bummer.
  4. I hope you make a thread on it so I can copy you without having to do all that pesky thinking myself.
  5. Found something, https://frostfighter.com/pickup-truck-rear-window-defrosters.htm?add-to-cart=1038 When it comes time to install my glass I will ask the auto glass shop what they think/know about adding rear defrost.
  6. Stunning display of deep MJ knowledge eaglescout! I wonder what circuit it ran off of? Has anyone laid eye on this snow leopard of an option?
  7. Nice! That is awesome! I see ScanGauge II is a similar product for the HO engines, but it's 4.8" wide so it won't fit it. https://www.scangauge.com/products/scangauge-ii/ I Imagine those switches close relays that carry the actual power for the winch?
  8. Gauges, switches, USB ports? What have you come up with?
  9. Has anyone ever added defrost to the rear windshield. Is after market defrost even a thing?
  10. Thanks for digging up that info!
  11. Wilwood valve is already in my shopping cart. I actually replaced the ballpoints in my 88 about 2 years ago and the prelaod insert was fine. My current goal is to have the body ready for paint by the end of the month. I'm installing 97+ doors,fenders, and front clip. When it gets back from paint I will install the interior and finish the rest of the engine bay work. I will probably be building the axles and rebuilding the t-case in November. Iv'e been taking pics so I should probably start a build thread. Thanks for all the help!
  12. Ahh, the hid that from me by making have to read. Thanks again.
  13. I was just curious is any Wilwood caliper bolt up to the Teraflex kit. Yes, as of now I am strongly leaning towards the Wilwood kits for both front and rear. 4 piston in the front and 2 in the rear. Theses kits, Front Brake Kit Part No.: 140-12576-DR , Rear Brake Kit Part No.: 140-12567-DR I know I will need to switch the steering knuckles on my 91 to those from my 88 for the front, and have to modify the backing plates mounting holes and use bearing preload spacers for the rears. I'm not yet sure how to deal with the ebrakes when using the Wilwood kit for the rear. Btw your help has been absolutely invaluable! I sincerely appreciate you.
  14. Thanks for the details. I recall someone mentioning something about a VW part that may address this. I'll have to search around.
  15. Pretty please elaborate. Are you referring to ebrake cable issues?
  16. The Teraflex kit seems to use calipers from 2003-2006 TJ/LJ. What Wilwood calipers bolt up to that? I don't see any calipers listed for that application from Wilwood. I am considering modifying he Wilwood kit for the Dana 35 so that I can have the better calipers ect. https://www.wilwood.com/BrakeKits/BrakeKitAdvisor
  17. Regarding the Wilwood Jeep Wrangler Dana 35 Rear Kit what are those two circular items that appear to be spacers? Circled in yellow.
  18. Hey thanks! That would be great information to have! What did you go with for calipers, pads, and rotors? Did you find any 2 piston calipers for the application?
  19. Are we both talking about this kit, 1987-90 YJ & 1984-90 XJ: Rear Disc Brake Conversion Kit It says the kit includes "Brake Preload Spacer (# 86262)" which is this, 1987-90 YJ & 1984-90 XJ: Rear Disc Brake Preload Spacer Is that not the spacer we are talking about?
  20. Good to know. I'm weighing the pros and cons of various approaches to the rears disk up grade.
  21. You're welcome, I'm sure you'll like them. If your not replaceing the stock hinge pins, just makes sure they are still about 1/4" so they fit the ID of the bushings well.
