EUREKA
Everything posted by EUREKA
The man has spoken. I'm sure you'll have plenty of vacuum for the brake booster, and we don't have vacuum advanced timing.
I didn't catch that there were two different noises.
So you do, or do not want advice on the stage 1 cam? You understand more lift and duration means less vacuum? And that "stage 1" means different things for different brands of cam so its best to go by actual lift and duration? Some are not great for daily drivers.
Just to be clear, you did previously state "As the engine warms up, the sound does get less noticeable". Guess that was in error.
Thanks. I figured it could hurt to take a close look and it paid off.
1988 Pioneer Long Bed Metric Ton Edition DD
EUREKA replied to EUREKA's topic in Member Projects: Your Comanches
I had no idea that the HVAC panel has a light. This is my first pre-91 jeep and I just assumed that the HVAC panel was not lighted. I happened to see one for sale while browsing and noticed what looked like a light bulb mounted in it. That should make things a bit easier to adjust at night. -
Checked off tip #10 today. "Trans plug connector refreshing". Made sure to also check the connector under the dash and the fuse. Also did #29 "Improving the fuel pump ground". I did it slightly siferntly. Instead of exposing some copper on the existing ground wire and warping the new ground around it, I cut the original wire, twisted both cut ends together with the new wire and soldered them. After soldering I slathered it in oxgard and put a piece of heat shrink on it. Not sure if everyone knows this but if you cut a piece of heat shrink with diagonal cutters while it is hot, it will melt the end of the tube closed. I also soldered on the ring terminal insted of just crimping it. Also removed the fuel filter mount and cleaned between the mount and the frame with a wire brush, as well as the screw itself before oxgarding everything. -
Thanks! -
Was that the metal ring that goes around each headlight? Or the bezel? Headlamp Bezel I don't believe that the headlight bezels are in good enough condition for me to want to buy them off of this jeep. My nearest junk yard is 8 hours rounds trip. But I have to eat lunch regardless of what I'm doing so I wouldn't include that.
I have a local guy with a 88 XJ with chrome grill ect. I think I'd prefer to buy a reproduction grill, headlight bezels, side marker bezels. Any opinions on this? What are fair prices for the chrome front bumper and upper and lower chrome header panel trim pieces? Sorry if this should have been in a different sub-forum.
