dante2
Everything posted by dante2
How much are you asking for it?
What color is that? It's so dirty it's hard to tell.
Still looking for a dark blue mini console...
It looks like part of the mod was done but not sure if it is complete or not. I got the breather tubes pulled from inside the cover and noticed that it has a hole drilled on the flat side closest to the cover. My question is how long should the tube be after cutting it down?
The gamblers look really great with that color. Wheels definitely make the vehicle.
Put the 1.25" Spidertrax spacers on the rear axle. Made a huge difference in the stance, looks so much better now. Also cleaned out the A/C drain on the firewall. No more wet carpet!
Both the 89 and my 94 YJ are both $25 a year in Oklahoma.
Yep need to spin them definitely didn't get them in the right spot.
I got the Dana 30 installed a couple of weeks ago and went together after some help from here with the LCA's. I put in new shocks and GC coils to get a couple inches to level the truck. I do have some noise going over bumps or dips coming from the front.end. Is it possible to have the lower end of the coil in the wrong position or are MJ's just noisy by nature? Possibly another issue? Hard to tell in the pic but the end of the coil is touching the back of the steering knuckle. https://www.dropbox.com/s/8my458ag2mo8270/IMG_20170711_153308_550.jpg?dl=0
Well yeah that would help a ton. Looks like I will have to go the PITA route with the engine still in it. Where about did you put the hole in the firewall?
Muddfoot are you running a floor shift for the trans? Did you drill a hole for the cable?
For those that have done the conversion what shifters did you use for 4wd and trans shifter? I stripped a 94? XJ of it's shifter parts but only a couple of holes on the trans cover plate line up. The 4wd shifter cup is hitting the body before any of the holes line up. Should I be looking for some older parts or do I need to do some cutting? Also can someone with a floor shift auto trans get a pic of where you made a hole for the cable? Thank you for your help.
Jeep driver thank you for the link but Fuel doesn't really have anything that interests me as far as designs. Strokermjcomanche very nice Comanche thank you. Tex06 yep like dat. thank you. Keep the pics coming everybody.
Looks like it's the navy blue.
I am leaning towards the ARE Outlaw 2 wheels but I am also thinking of going with all black trim and wheels. Would like to see the whole truck in the pics with black wheels. Color of the truck itself doesn't matter. TIA
I have a white MJ with blue interior. I have a gray column and maroon mini console that I want to paint to match. What paint and color should I look for?
I am looking for a blue mini console in good condition. I have a maroon one that I will trade for if you happen to need that color. Thank you.
Thanks for all of the tips guys. Waiting on a M12x1.75 castle nut for the tie rod to finish this up.
shelbyluvv you won the internet today! I have been fighting with that axle for several hours and your trick took about 25 minutes. Had to fiddle with getting the jack set right but after that it was lift up or down to get the bolts in. Thank you very much huge help!
So you think I should pull the lower bolts out to get the other upper in then go after the lowers?
I am doing the 4wd swap and have run into an issue with the front axle. Axle is in except for the pass side upper control arm. I can't get that last bolt to line up. It needs to move back about a 1/2 inch to get the bolt in. Any ideas on what I am doing wrong?
Little different flavor, spotted on my way home a few days ago.
Recipient vehicle for 88 4.0 4X4 5 speed drivetrain
dante2 replied to Gene's topic in MJ Tech: Modification and Repairs
Did you buy the 92 Don? It looks real clean in the pic. -
1990 Automatic Leaking on Driver's side
dante2 replied to texasjack's topic in MJ Tech: Modification and Repairs
See what your talking about in the pic? https://images.search.yahoo.com/yhs/search;_ylt=AwrT6V3fQh5ZSAQAMzcnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Aw4+Trans+Images&fr=yhs-mozilla-001&hspart=mozilla&hsimp=yhs-001#id=3&iurl=http%3A%2F%2Fwww.quadratec.com%2FAssets%2FImages%2F120169%2F120169-lg.jpg&action=click -
Tips 1,3,5,8,10,11,12,13,and 21 to date.
