Everything posted by Torq_Shep
Hell yeah! Congrats! That is a pretty big accomplishment!
To be honest I had to google OPDA. For some reason I assumed they used a different oil pump drive method on the 00-01s. Did not realize they literally just made this =P
Hi That Guy! Your harness is slick AF I just don't think it is quite right for my application. I already have the ECU and a 1996 dash and engine harness that I am in the process of striping, cleaning, re-wrapping (maybe add some pins) etc. I understand the pricing 100% as custom building harnesses takes a ton of time, I have a background in engine stand testing... With that being said if you want to sell some pins so I can add a pigtail or two to the harness I am rebuilding to experiment with COP and potentially trying to use the other unused O2 signal pins to send data back to ECU for OBD2 data logging of wideband and maybe a knock box if I get crazy enough... I have a loose 1991 Dash harness I am going to compare to the 1996 dash harness to see what the differences are when interfacing with the engine harness. I have also heard that the 00-01 ECUs don't play nice with the 1991-1996 Tachometer. In any case if you are willing to let me pick your brain a bit I am still in the research phase of doing this. Also curious on if my COP plan is even feasible with the 1991-1999 Cam Pos sensor in the distributor can be left in place and work with an 00-01 ECU.
Definitely some sarcasm in the title =P I was astonished when I read it...
Also, and this is a long shot, but if I did this conversion I may pigtail the pins listed in 2000-2001 models for COP in case I want to try converting to COP for ignition timing. It looks like you can do it without needing the 00-01 CAM pos sensor if you just leave the dizzy in place (which also runs the oil pump).
I have not considered that but if I convert to OBD2 there is no reason I can't have Chris or Ryan tune it still. I just downloaded a 2005 TJ 4.0L tune file to look at and it is fairly sparse. Still would like to see a 1996 tune file as I bet it is even more sparse (no/limited spark tables). However, it has enough tunability to get the fueling and engine fan stuff dialed in. The other nice thing about OBD2 with HPT would be for data logging.
https://www.facebook.com/marketplace/item/884212465762405/ Its kinda cool? But I am not sure it is THAT cool...
I have seen that guys harness and although it is slick I don't really consider it a full conversion. More of a novelty that would allow me to pre-tune an ecu before doing the wiring conversion. Plus its kinda pricy (a little less than 1/2 of the terminator)
I 100% want to fully integrate it. It has to be easier than getting modern OBD2 engines to run in a test cell. Additionally, the 1996 ECU is tunable with HPTuners now which is a HUGE plus. The terminator X system is more appealing to me than getting another canned tune ECU. The jeep has a locked "tuned" ecu and it still doesn't feel quite right. I am very familiar with HPT and tuning engines for various functions so being able to tune the engine for reliability and drivability I think will not be an issue. It would however be nice to have timing control...
Stupid question (maybe)
Torq_Shep replied to Renoenvy08's topic in MJ Tech: Modification and Repairs
To my knowledge AX-15 was always 23-spline so 1994 XJ NP231 should be identical to any year AX-15 equipped NP231 MJ/XJ. -
Probably. Early Aw4s had 21 splines. I don't remember the cross over year but I think it was 1990? -
I am planning to do this to my jeep. Currently I have a 1996 OBD2 engine and dash harness, 4.0L MT ECU, does anyone have the wiring diagrams for the 1991 and the 1996 engines? Additionally, does anyone know what sensors need to be changed?
Scaleless's '87 SporTruck Project
Torq_Shep replied to scaleless's topic in Member Projects: Your Comanches
Gotta update your signature then! -
Tweeters are responsible for the highs and sometimes high-mids on a stereo system. Many modern aftermarket speakers (cheaper models typically) have the tweeters built-in in the center of the speaker. Older vehicles either didnt have tweeters or they had them in one spot on "premium" sound. In the case of our jeeps, the lower kick panels have grilles for these speakers but they are hardly ever present unless you had an "accusound by Jensen" package. Even if they were present they sucked...
Dead Jeep has used ones for $25 so I just bought those instead =P
Dead jeep has used ones for $25 so I just bought those =P
So I bought all of my components from crutchfield. Morel Maximo 5 Component fronts and Morel Maximo 5 coax rear, TJ adapter plates, 16 ga copper speaker wire, Soundstream Reserve Mini 75w x4, Duetsch knock off disconnects for the speakers, etc etc. Y'all bought all the Team Cherokee tweeters though so now I need to rig up mounts for the tweeters...
DAMNIT Y'ALL BOUGHT THEM ALL. I just bought my components from crutchfield for the audio and went to buy these for the brackets and TC no longer has them. Should have known better. In any case I am now on the hunt for a set again =P
I have wrapped maybe 10 harnesses and I feel like every time I do one I wrap it slightly differently. I usually resort to 3m Self Adhesive at junctions, appropriate split loom, then self adhesive over the split loom. Sometimes I wrap long sections of the harness, put it in split loom, then wrap again. Sometimes I use the expensive cloth tape stuff. Does anyone have a tried and true "best" way to wrap a harness?
My connector looks like roofing tar
Torq_Shep replied to Kickin’Chicken's topic in MJ Tech: Modification and Repairs
Its not super easy but it isnt that hard either. It just has one bolt (I think 7mm) holding the plug together but there isnt a lot of room to get down there. -
I guarantee that the connector going to your under dash fuse harness is in identical shape just FYI. -
Very typical. Most people delete this connector entirely. However, contact cleaner and a toothbrush can clean that up and you can put Di-electric grease back in the connector afterward. -
So if I do them in the under dash panel I am willing to modify those brackets as well. The idea would be that instead of pointing them straight out like factory (vents are angled down but tweeters are pointed straight out, I would probably try and mount them angled slightly upward to combat the terrible positioning. I agree on the sail panels, I think I have about 2 extra sets of those, but then I lose the charming little adjuster knobs for the mirrors that totally function correctly :V In any case I will definitely be doing a build thread on this truck. I am in the process of reconstructing what I know was down by limey so that I have a good place to start. The audio is going to get done at the same time I install a rebuilt hvac box and install a re-worked harness, fuse block, with OBD2 provisions for the interior.
I am using knock off deutsch connectors for all of my stuff but otherwise this is my exact plan...
