Everything posted by PatO
I bought mine new (1991), I was doing a lot home remodeling / hauling for my house back then and was replacing a little Mitsubishi turbo-diesel which only had a 900# payload. The Metric Ton was was the best capacity in the mid size line up. I still drop 1500# of gravel in the back every now and then and haul it home. It's also fun to dick with how it looks! :)
http://www.andysautosport.com/jeep/1984_1992_comanche/interior/floor_pans/sherman/ try here
I've had one the last year or so. I'm quite sure I ordered it from CoverKing through CostCo for about $25. It hides the cracks and has a good fit. For a picture send me an email to: simple nest @ san . rr . com remove the spaces, it is a trash account so not concerned if it gets spammed.
yes factory skid, no modifications required for bumper Here is a closer view I found of the front. It also is my profile picture. http://www.facebook.com/photo.php?fbid=10201643380749545&l=43f15d6807
http://www.facebook.com/photo.php?fbid=3024366571400&l=8485e99870 You can try viewing this... hopefully it will work. If not I'll check back later. Pat
I ignored my A/C not working for several years until the compressor froze up about 9 months ago. It contaminated the entire system with shrapnel so every major component got replaced with new. It also didn't help when they broke a fitting on the under the dash evaporator necessitating even more disassembly and parts. Anyway you might want to get one of those replacement idler pulleys if you want to defer decisions on what to do about it. That cold air blowing out of my vents now cost about $1800 vs what would have been a $3-400 conversion kit if I wouldn't have procrastinated.
No; One should add up all of the positive and negative responses and make their own informed decision. I personally would give more weight to negative responses. I would also use responses such as mine to trigger additional research which is readily available on this business using google. I would also check the BBB. There is a wealth of information available that would lead any resourceful person to not want to order from RRO. I personally waited 5 months for a set of Bushwackers.fender flares.
STAY AWAY FROM ROCKY ROAD!!!!!!!!!!
Vehicle Creeps In 1St Gear With Clutch Fully Engaged
PatO replied to PatO's topic in MJ Tech: Modification and Repairs
Yes that pilot bushing has been trouble in the past, other symptoms might point to that too. -
I bled the system and it helped shifting a tad but made no real difference to the noticeable creep when in first gear and the clutch pedal is pushed to the floor. On level ground and no brakes on it will creep a bit sometimes but not all of the time. A light brake will hold it and there is no change on the tach when the brake is applied. I'm going assume that the hydraulic throwout bearing is not doing its full job but I think I will bleed it one more time just in case. Any comments are welcome but sometime soon I will be taking it to a shop to be figured out. It's not the original clutch/ pressure plate but it might have 100K on it. Thanx for your time and hard earned experience. Pat P.S. I turned 166666 miles today!!! :)
I replaced my slider last year. Ordered it somewhere off the internet made by CLR, cost $175, included the urethane. The old urethane was very difficult to remove. The old frame had a broken window so didn't have to be careful with the old frame but it would be really hard to remove and reglue.
Well that was worthy of going right out and checking because I moved that canister to the engine compartment last year when I installed the Bushwackers & JCR bumper. I found that the hose had popped out of the T probably when I was handling it last weekend when topping off some fluids and checking for AC refrigerant leaks which I've experienced twice now since I had the AC system replaced two months ago. Anyway Spot On answer Pete. Thanks!!!!!!!!!!!! You saved me some expensive embarrassment I'm sure! :)
Would anyone have any ideas on the most likely cause for no matter what position the slider (AC Max, AC, Vent, Heat or Defrost) is in air is only directed at the defrost vents. Maybe a linkage under the dash? The dash was off 2 months ago for some AC work at a shop so I wonder if it might be related to that. They have been good about honoring their warranty but the dash work was a real pain for them. Anyway I don't know the layout under there so ideas are appreciated. Pat
Rear Bumper Ideas And Opinions
PatO replied to Southpaw26's topic in MJ Tech: Modification and Repairs
I think there was $25 of or so, not sure anymore but with shipping to San Diego the total was $590. -
Like 86Customanche my back bumper is on the vendors website. Picture #2 before my paint job. I always meant to send them a better picture but never did. What is not mentioned is that bumper is Line-X'd.which is not one of their options. I got it raw and put another $100+ into the Line-X. The bumper is awesome but pricy! http://www.hansonoffroad.com/proddetail.php?prod=MJ4002-P I've had 2 Fey bumpers and they only last 6-8 years before rusting out. -
Stay very, very far away from Rocky Road Outfitters. Check any reviews you can find on any internet business you are considering. Quadratec has been more than OK with my orders with them. Pay a little more with them but have customer service and a really good selection.
Repaint- Need Help Picking A Color.
PatO replied to sgcomanche2's topic in Member Projects: Your Comanches
http://www.facebook.com/photo.php?fbid=3024366571400&set=a.2753614722773.152919.1329835029&type=3&theater This truck was black when I bought it, than silver for 10 years and now metallic grey. -
JCR with tube and no winch
Anything I should consider when buying a new radiator?
PatO replied to Jerry's topic in MJ Tech: Modification and Repairs
I'm not sure about the '86 but three months ago I got a 3 row all metal for my '91 from RadiatorBarn. Had all of tabs and slots for a perfect fit! -
Thanks for all the compliments! Right now till I get the camper shell rebuilt it sits in my rear window behind passenger head rest. Probably not legal... then I'll mount it on the camper door with a lighted frame. Smoke would have been good with the new paint but didn't think about it. I bought a new grill, both bezels, turn signal lenses and the parking lights lenses as part of its refresh in the front. Neither "Made in Taiwan" bezel would fit so I just threw them away and just painted the old ( :wavey: :wavey: $50) Pat O
"Rev -" was when I bought it new + the subsequent lift and improvements before 1999 "Rev A" was my 1999 freshen up with silver paint, Callen camper shell, blade style steel wheels & mud terrains, see current profile picture. "Rev B" is my 2011 freshen up now with 162000 miles [*:j9vsyypp] Hanson back bumper (Line-X'd) [*:j9vsyypp] JCR pre-runner front bumper [*:j9vsyypp] Bushwacker cutout flares [*:j9vsyypp] Other Line-X; around rear window, lower quarter panel, renew of 20 yr old Rhino lining [*:j9vsyypp] new paint color (MAACO - I do not recommend them) [*:j9vsyypp] new 16" Blackrock soft 8 rims & Gorilla spline nuts [*:j9vsyypp] new 265-75/R16 Hankook All Terrains [*:j9vsyypp] new rear window [*:j9vsyypp] new California Cat [*:j9vsyypp] new radiator & hoses, thermostat, heater hoses, tuneup etc. Heading into the spring & suspension next, new bushing, shocks and anything worn out.
A little tech help please, I just replaced all my heater hoses and the heater valve which I broke when I was taking off one of the hoses to it. The heater valve has a vacuum assist operator on it. I had it apart for several weeks and now I can't the find small vacuum hose that connects to it. I may have taken it off but I don't have any extra parts so I think it is dangling there somewhere but can't find it. Can someone tell me where it originates from? A 91 - 4 liter; this is the black heater valve with the 4 heater hoses connected to it between the heater core and the engine. Thanks a bunch and back to Chilton's to see if I can find a diagram. Pat NEVER MIND, I found it, it comes out of the firewall above the A/C penetrations and is grey so it looked like a wire. All those little OEM heater hoses sections are pricey!
Sorry to be a tease but if you find one it looks like this next to the stock:
Me either my 91 LWB does not have it and I bought it new.
cheapy rear leaf spring tech
PatO replied to Scottanchee's topic in MJ Tech: Modification and Repairs
Too bad you are so far away (I'm in San Diego) I have a pair of the stock Big Ton rear leaf packs in my garage. They have the 2 very beefy overload leafs underneath the standard leafs. The 2 overloads are about 1.5" thick and the 3 leaf main pack is over 1". I took them off in 1996 and have been in the garage attic ever since. One of the packs only has a few thousand miles on it as it was a replacement for an off-road misadventure. I replaced them with a military wrap custom 5" lift set. That set was way overbuilt (6 main and 2 overload leafs) and I took one of the short overloads out as it hung down so far. They would make a great 5/8" spacer. Pat O
