adobson06
Everything posted by adobson06
  1. ok because i have a wire screwed to the metal behind the tail light and its just hanging there its not connected to anything
  2. problem ended up being a crack in the ignition coil..... Id still like to know where the ground behind the tail light is suppose to run to
  3. yes that ground the one behind the driverside tail light where is it suppose to run to?
  4. fuel filter was changed as well couple weeks ago yes i do have brake lights the left turn signal doesnt work for some reason but i have taillights brake lights and backup lights any idea where the ground wire that is mounted to the box is suppose to run to and connect?
  5. see the ground behind the tailight has not been connected since ive owned the truck and ive always wondered where its suppose to connect to i wonder if that would solve my issue or at least help.....It's not connected and still starts?Just put it back into its existing position... Well clean to bare metal then bolt it down with a nut and extra washer so it can have a good ground for the fuel pump... If you can post pics of it so it'll help us help you how to reinstall it .... alright i can do that because all there is right now is a wire about 3-4 inches long bolted to the bed and then it goes no where like it was cut not sure what its suppose to mount to but i'll snap some pics and post them asap
  6. see the ground behind the tailight has not been connected since ive owned the truck and ive always wondered where its suppose to connect to i wonder if that would solve my issue or at least help.....
  7. i havent tried that yet.... was also thinking possibly the intake temp sensor
  8. here we go again 86 jeep comanche 93 jeep cherokee 2.5l engine low idle runs good when cold as the idle drops to normal begins to misfire and it gets worse the warmer it gets to the point it dies and starts itself again.... driving down the road at a low rpm runs fine put any type of pressure on the pedal to accelerate it begins to buck and misfire terrible....... drove to work today stopped to turn and the truck died went to start it, and had to hold my foot to the floor to get it to start.... seems like it lacks fuel but pump sending unit resistor and pressure regulator are brand new. i pulled the plugs to see what was going on and all of the plugs had a nice brown tint to them except the furthest back plug which was still sorta white.... list of parts i changed today with no changes.... TPS Distributor temperature sensor Crank sensor fuel pump fuel injector o-rings parts changed recently..... fuel pump ballast resistor fuel pressure regulator spark plugs spark plug wires cap rotor I checked to see if it was the o2 sensor by unplugging and starting the engine and it did not run any better. i am running out of parts to replace and I'm begining to get annoyed at this point.. I'm about to replace every injector and the coil. i checked the ohms rating of each injector and they were all the same across the board..... i checked the primary and secondary of the coil and it was within the ohms ratings.....
  9. update on my problem after new pump/sending unit pressure regulator re-running new vaccum lines little over 100 bucks in parts it was the ballast all along bought one for six bucks threw it on and boom problem solved.... :wall:
  10. alright i'll give that a shot and see if it works thanks for all of the quick answers everyone
  11. tried old pump in brand new sending unit and tried brand new pump in new sending unit both produced same numbers the ballast resistor does not look healthy though was wondering if there were specs for what the voltage should be at while running so i could see if there is a possible voltage drop while the vehicle is running.... not sure scratching my head on this one may try to replace the ballast tonight and go from there
  12. this was all done before i got the truck i have a copy of the title to the engine its a 2.5 out of a 93 cherokee....... i hooked up a fuel pressure tester first prime its over 20 after that its below 20lbs it also has a filter for a 93 cherokee hooked up i just replaced it actually... and i used a sending unit and pump out of a 93 cherokee as well pump and sending unit are brand new filter is brand new vaccum lines have been freshened up, and the regulator is brand new as well.
  13. Back again guys this time it's a fuel problem was going up a hill it had been bucking for about 40 miles finally it died mid way up the hill it'll start and run for about 10 seconds and die. So I changed the pump fuel pressure regulator vacuum lines etc.... now it'll start perfectly and stay running but has zero power and if you Rev it it almost dies after letting off its also back firing through the throttle body I'm guessing a voltage problem to the pump but any other options would be great to check into
  14. I haven't done it yet I am going to attempt to run a xj interior harness and I may just use the gauge cluster from an xj and see how it works anything has to be better than what I got
  15. i may be wrong about fuse panel i just know on the T/a all the wires for the dash were mounted into it and i know they are a two piece design block for the engine bay bolts to the fuse box for the interior wasnt sure if the comanche was the same i was just hoping to pull all of these terrible wires out with the box with "one swift motion" and replace it with "fresh" old wires out of a junkyard cherokee that hasnt been splice and trashed.. when i took the dash out and replaced it the only things that were removed were roof lights that the kid spliced into a line that i assume turned them on when the light switch was engaged. the other issue is when I'm driving down the road at night i don't even have to hit a bump and the headlights will randomly shut off forcing me to to hold the high beams on by hand while i steer and shift (fantastic multi tasker right there) i will have to take pictures and upload them this thing is straight out of a horror film.. the weird thing is there is a white wire with way to much slack that runs from the cab to back lights with a couple cheapy butt connecters that the guy splice into i wanna say both turn signals poor poor mj
  16. thats what I'm shooting for the engine harness is untouched thats what I'm confused about makes zero sense to me i was going to check and see if i could find a box cherokee with a 2.5 and just unbolt the interior harness and rebolt it to mine i've been struggling with this thing for over a week and i would think it would be a hell of a lot easier to just replace the entire fuse box for the interior but i wasnt sure... thanks for the quick response
  17. my 86 was previously loved by some college student who did a 2.8 to a 2.5 swap i decided to replace the enire dash and not surprised at all almost every single wire in the dash have a terrible cheap splice done to them.... After replacing the dash and clicking everything back together now when i hit the brakes the dash lights come on with the brake lights, and the left turn signal doesnt work unless the lights are off or if i don't hit the brakes, but it still doesnt work after that just flashes the both rear lights, and the front left turn signal works though...my question is can i just rip the entire fuse box out for the interior and find one out of a same year or near same year cherokee? it doesnt appear anything was spliced in the engine bay so i wasnt sure.... ive done this before in my close to ancient trans am, but I'm not sure if for these things it would have to be engine specific, or if it would have to be out of a mj thanks
  18. i chopped my cat off and threw a just a plain dynomax muffler as in their words "performance muffler"... didnt have time to throw the tailpipe back on.... not two days later i had a full tailpipe thrown on was way too loud in the cab to not have it. gives it a much better sound over stock but its not too obnoxious
  19. do you think they should be replaced before i go on any off roading adventures i don't want to have to end up replacing axles if i can prevent it for 8 bucks a piece
  20. i've been told dupli color rust fix works great sprays right over rust and turns it black comes in a rattle can its suppose to seal it to stop rust, or if you've got the time por 15 works wonders but is a process......
  21. i guess that would be considered a cv shaft i havent torn it apart but yes i am referring to the front inboard stub axles 25 looks to be right.... i assume it would be 23 for the dust cover just looks like mine is closer to the teeth that slide into the housing wasnt sure if i should replace them or not seeing how they are rotted right out for the most parts just didnt want to run into trouble if i take the truck on a off road adventure :P ... thanks again for the help
  22. I had a quick question and I'm pretty sure its a stupid question, but here it goes anyways..... my 86 comanche where the spindle goes into the axle housing there seems to be a rusty piece of metal left of what looks like to be a seal I'm not sure if its just a dust seal or what. Its kind of hard to explain without a picture which i will try to get later, but if you follow the ujoint off the wheel towards the center of the axle right where the spindle enters the housing it looks like there are remains of a seal is it a necessity to have that seal in place? there doesnt appear to be any fluid leaking from the axle on either side but both seals are rotted right out... Are they known as inner spindle seals or our spindle seals? thanks for any help in advance.....
  23. update to my track bar issue the previous owner had taken the original bracket off of the truck and welded a cob job bracket to it so it could be a double shear... Luckly i had a track bar and bracket off of a 93 laying around so that gets changed asap
  24. alright i will have to check it out thank you for the help just thought it was weird that there was a double eyelid bar on this truck without a lift in the truck... I guess it made sense why it has massive welds at one end must have had the same issue and just cobbed it...
  25. I have a 86 comanche 4wd first jeep i've ever owned, and the person who owned this beast before me had welded the track bar in a couple places as a fix, but i am ready to do a full overhaul of the truck and the front end is my starting point. The issue I'm running into is that the track bar on my comanche has double eyelids... Every single track bar i look up has an eyelid and and ball joint... I see if you do a lift kit some companies offer a double eyelid set up, but the truck doesnt have a lift in it. Was curious if anyone else had this type of issue thanks for any help in advance.....
