88ComancheMitch
Everything posted by 88ComancheMitch
  1. Well, one bolt was loose. Exhaust cracked at the rear collector. Going to replace the MAP sensor today hopefully and at least fix the high idle and 12mpg
  2. It is the 88. I have a exhaust manifold leak. I eliminated that as the problem thinking that if it was a leak there that it would fluxuate idle and not hold pretty much steady. I'll check them in the morning. I thought my leak was a cracked manifold. Haven't checked to see exactly where its leaking because I'm just going to do I a 99+ intake and header.
  3. I have a high-idle issue. Symptoms- In park/neutral idle is between 1900-2200. Sometimes surging high as 2500+ and as low as 1600. In any gear (R, D, 1-2, 3) idle is about 1100-1300. These idles are pretty much consistent. Every now and then, for a split second, idle will drop when in Neutral or Park to around 600-800 and sound like it's going to die/has a terrible miss. I checked the voltages, and when the idle is at 2000+, the MAP sensor, wire "B" is between .07V and 1.1V. From what I'm reading it needs to be 1.2V-2.1V or something similar. I was lucky enough to catch the reading at the idle dropped, and when it dropped to ~900RPM in Park, the Voltage reading was ~1.5-1.8V. Is my MAP sensor bad, or am I having another issue with vacuum somewhere?
  4. Haha, Yea, no sleep and all work and school makes me not want to do anything when I go have free time.
  5. Got bored so I swapped in the injectors I had sitting around.
  6. Where abouts do you live? I see you took a trip around the highlands. I live in fairdale.
  7. School has been killing me, and slowing down the project, but I am still working on it as I can. I got the gauges all working. Painted more of the trim. Next thing to do is rework the vacuum lines. Here's a little entertainment
  8. Definitely changing the color to tan now...I have to redo this when I get a new trim piece, but I really love this color combo...
  9. Old tank. Hole got massive. Not sure if I jacked it up and added to the stress crack or what.... New tank. Spray on rustoleum bad liner as a coating.
  10. No doors! Actually removable doors...but just something to add to the fun factor
  11. After looking at some pics, I don't think this is it. You might look to verify... Here is a picture of what it looks like...this one has an extension on it, but looks relatively the same.
  12. Does it go the load leveling thing or whatever it's called? The thing that measures the weight and brakes accordingly?
  13. Well...I would post pics, but just a PSA, self-etching primer does not mix with Plast0i-Dip....
  14. Thanks. Started painting it this morning. I'll post pics tonight
  15. Starting to come together. Stopping for the night. Debating on painting the glove box for green and the bezel around the gauges green. Any one want to weigh in on the topic?
  16. While I'm waiting for the gas tank and all I figured I might as well work on the interior some. Ive said it once and I'm sure I'll say it a million times, its not going to be a show truck. Just a DD and work truck. Thats why I'm cheating on the interior with plasti dip. :-)
  17. Wow. I'm not sure why it would be that much. Unless they're just saying a crazy high number because they don't want to do it. and if you said yes then they'd make a ton on it incase it leaked or something....
  18. Welp....gas tank should be here monday or tuesday.....
  19. I <3 yellow. And I really like the Yellow look. It's pretty unique.
  20. Ordered a oil pressure sending unit. It should be here Monday I hope. As for the temp, it's not working. Does anyone know if the threading on the ~88 and ~98 temp sensors are the same? Can I buy a temp sensor for a 88 and replace the one on my 98 motor? Thanks for an help in advance!
  21. Just messing around ^^ Getting the interior ready. The 2 places I stopped at today to get black plasti-dip were sold out. So I didn't get any. Going to go tomorrow and get some while I'm out. I'll be wrapping up some of the rest of the interior then and it will look a lot more complete. Here it is for now though...
  22. Yea. I work about 35 hours a week during the night, and then have college...on summer break for the rest of this week, and then progress will slow down for a month. I'm hoping to have everything "done" by August.
  23. http://street2mud.com/webfiles/AMC%20Engine%20codes.pdf I think this is what you're looking for. About to head back out to work on the truck, stopped for a snack...
