Well, I'll make an introduction thread/build thread when I get home (at work now! shhh!), but I have a few quesions.
1988 Jeep Comanche Pioneer
98 4.0 H.O. Swap (?)
Auto Trans
So, here are my questions...
Swapped the full gauge cluster with tach/speedo/and all sensory gauges. I know that I need to swap the temp sending unit/oil sending unit to get those gaugest to work. I have an issue though...
Everything that I could find online was pertaining to the stock Renix 4.0, and not the H.O. 4.0. I looked at the sensors, and it looks like whoever did the swap kept the old sensors (smaller oil pressure unit, 2 wire temp sensor). The temp sensor is not on the rear of the block like a Renix, it is in the front (not on the block). The oil guage moves, but doesn't really fluctuate, as in it's not working/not accurate. Temps stays dead, where as it did at one time jump all over the place.
Question comes to be:
Do I still buy the same sending units that are in the write ups for the gauge cluster swap, and run a wire from the temp unit to the old connector for the temp sending unit? Can I use the current 2 wire sending unit and run a wire from it? I'm sure I need to buy the new oil sending unit, but will it fit okay threading wise if I am using the newer block?
My last question for this thread pertaints to the speedo on the cluster. It reads accutare, but jumps 1-3mph constantly. I know I've read alot about bad grounds, is this where I should start? Or is it likely that the gears in the cluster are stripped/bad?
