Everything posted by STROKERMJ
There were 500 rigs at PAP on Saturday -->pics here<-- STROKERMJ
Well its official Paragon will be closed as of monday, if you wanted to go this weekend is the time it will only cost $5 to get in sat and sun. STROKER
Thinking of snagging some baby swampers...
STROKERMJ replied to Pete M's topic in MJ Tech: Modification and Repairs
I used to run 32" tsl/sx's worked great offroad but were not meant for street drivin' STROKER MJ -
http://petitionspot.com/petitions/savePAP/ Paragon AP is in danger of being shutdown by the land owner, they wanna push Paragon out and sell the land to a developer, the land-owner is trying to "void" their lease..... http://www.paragonap.com/forum/showthread.php?t=11673 PLEASE SHOW YOUR SUPPORT, east coast wheelin is quickly going away. STROKERMJ[/url]
IIRC some year XJ hatch struts, the little ball "thingy" unscrews from the strut. STROKER MJ
anyone notice the xj four dour line on the rear door, looks like they took a bed and mounted it. STROKER MJ
Installing Fog Lights
STROKERMJ replied to Kenosha Warrior's topic in MJ Tech: Modification and Repairs
In my experiences a switch is a switch, but the ground is key, I would select a better ground than the bumper more towards the frame. You should use a relay for the lights, here is a WEB SITEthat should help you wire the lights with a relay. You're gonna use a standard relay, that you can pick up at any auto parts store. A quick run down however would be this On a standard relay you will have 4 or 5 post's to connect to, 85, 86, 87, 87A, 30, not all relays come with the 87A post. Posts 87 and 30 are the load side(lights, fan etc) of the relay Posts 85 and 86 are a low current side i.e. power coming from switch You will wire a 12 volt source to leg 87 then the hot side of the lights to 30. Then the 12 volts coming from the switch will goto 85 then ground post 86 of the relay. STROKER MJ -
STROKER CRANK KIT/STROKER LINKS FOR INFO
STROKERMJ replied to Rokhound's topic in MJ Tech: Modification and Repairs
$800.00 for a crank....WOW. All you really need is the crank from and old 258 4.2 block, 4.0 or 4.2 rods a source for a cam and pistons and a good machine shop. Wouldn't advise going bigger than a 4.6, the cylinder walls won't handle the heat, therefore cutting your longevity of the motor. STROKERMJ -
Alcan Springs with the SOA. STROKERMJ
everybody's opinion on the best track bars
STROKERMJ replied to bigwormskidoo's topic in MJ Tech: Modification and Repairs
I'm a rock krawler fan myself, I am running their LA kit and it's definatley beefy. But then again I am still running my RE bar, so take it as it is. STROKERMJ -
Changing unit bearings...
STROKERMJ replied to CWLONGSHOT's topic in MJ Tech: Modification and Repairs
"year" breaks in my experience don't mean sh!%, when it comes to the everyday parts store, even my parts guy has gotten me wrong bearings before, some manufacturers think they're all the same and produce them that way. I would return them and go thru the shelf and find the correct ones or just do a conversion and get rid of those things.... STROKERMJ -
That's how my 4.6 came to life... STROKERMJ
Quick drain all fluids run it for about 15min and repeat. Did any H2O get in the intake, looks like it may have? I used to drive thru creeks in a local mud hole with my old XJ, flooded the motor with water drained it started it and the motor blew 3 days later sitting in traffic, all because I didn't change the oil....DOH.... STROKERMJ
you could also look at http://www.fastenal.com/web/products/detail.ex?sku=0122048 the bolts will be M14x120 or 125mm grade 10.9. HTH STROKERMJ
You can goto my website for more pics here's 1. I'm at 8" and 36's STROKERMJ
jc whitney also has the carpet molded and different colors thats what I put in. STROKERMJ
A bad lesson learned
Hey Eagle how r ya. If you're talking about me then it was a little more than bruising. In fact I tore 80% of the ligaments in my left ankle and broke a bone in my wrist, put me out for awhile. STROKERMJ -
New to the club, heres the comanche
STROKERMJ replied to STROKERMJ's topic in Member Projects: Your Comanches
Actually, he did know he's just glad I didn't hack it up and tube everything. STROKERMJ -
Looks like an AW-4 to me. STROKERMJ
All that is left is to build a back bumper, mount the pass. seat and build tail light boxes. click me and goto the bottom STROKERMJ
Sweet, when I picked mine up from Eagle, it looked "almost" rust free, then when I pulled all the interior out, OH BOY, I ended up replacing the drivers side floor board. STROKERMJ
Looks good. I'll drive it if you don't want to... :P STROKERMJ
Thanks guys, as far as specs its essentially all the hard parts from the XJ. The MJ is an 87, 4.6 stroker motor, 8.25" of lift, 36" TSL Swampers, custom dash, cage, wiring and soon custom bumpers, york OBA. Alcan leafs, RockKrawler coils and LA's, rustys x-fer skid and steering box brace, custom steering box frame brace, oh and hydro assist steering. Thats it in a nut shell. STROKERMJ -
Nice lookin rig. Good work. Aren't comanche's just bad @$$ looking when lifted STROKERMJ
Still under construction but I basically took 98% of the "hard parts" from my XJ and transfered them over to the MJ. here's what I started with STROKERMJ
