JPinnell
Contact Methods
  • Website URL
    http://www.johnpinnell.com
    Stanton, MO
JPinnell's Achievements
  1. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120072858874 Looks pretty decent. This appears to be the elusive one that pics have been floating around the net for 2-3yrs. A bit more than I can afford now . . . - JP
  2. Get a late '90s to early 2000 Ranger 60/40 Bench. My folks have a 2001 Ranger Extra Cab and I've measured the seat. It looks to be the exact width, height, length, etc. and it even has a cutout for the shifter. I did have a '96 Dakota and the bench in it was bigger than the MJ. I plan to hit the yards this Spring and swap it in instead of my current bench. - JP
  3. What are you smoking? 5000lbs is the rating for an XJ or MJ. That long of a trailer, the high and large frontal area, much less the weight would be entirely too much to pull with an MJ. I have no doubt it will move it I just question the stopping. If you want to pull a 5th Wheel then I'd be looking for a 3/4 ton full sized pickup. You could look for a bumper pull trailer that's a bit smaller and have good luck. - JP
  4. Espo.com sells replacement stock leaf packs for $200. If you pay an extra $40 they'll send you some for a 2" Lift. I've got a set on my '89 but it's still in the Project Phase so I haven't ridden on them yet. They appear quite sturdy, more arch than stock, and have new bushings, etc. I'm using these leafs, front HD Coils from CarQuest, and D30/D44 axles from an auto which will give me better gearing to run 30"-31" tires with my 5spd. - JP
