Automan2164
Administrators
Everything posted by Automan2164
  1. Oh yeah, FWIW, if anyone wants to know the weight of their MJ, there is an abandoned weigh station by my place with the scale still on. Rob L. :dunno:
  2. Yeah, lookout... http://sfbay.craigslist.org/sby/cto/1512093097.html Rob L.
  3. Not yet :dunno: But he did say he was going to wait until he had a reason to get back to it. Rob L.
  4. Agree. I think you should be able to carry a weapon until you prove that you can't control yourself or are unsafe. Rob L. :USAflag:
  5. You lucky son of a... Rob L. ;)
  6. IIRC, if it is a true Eliminator, it came with black bumpers, and a color matched grille... Someone has been messing around there... :roll: Rob L.
  7. Eh, I ended up having to work that day anywho... Making $30 an hour... But a wedding? Pssh. Rob L. ;)
  8. You should definately blow off that wedding to visit with the comanche club guys... Rob L.
  9. :fool: Quiet junior. Rob L. :D
  10. Merged the threads... :cheers: Rob L.
  11. :cry: Rob L.
  12. yeah i guess. anyways, count me out for this one. What if we go to the Tilted Kilt in Madison? Rob L.
  13. Not on these... Rob L. :smart:
  14. Yep, but I will come a swinging with that sensor if I pull it and there is a HUGE air pocket... :roll: Rob L.
  15. For some air that will work, but these RENIX 4.0L's are a son-of-a if you don't bleed them properly. Rob L.
  16. You guys are forgetting this is the CLOSED system!!!! Jake, do i need to come over there and beat you with the temp sender? In this system, it won't burp like an open. Leaving the cap off does no real good. You HAVE TO park it facing down hill while cold, pull the rear sender, and bleed it off. I was assuming you bled it like I told you to after doing the t-stat. It will act like it is UNTIL YOU bleed it. Rob L. :fool:
  17. I am assuming the garage is still standing though? Rob L.
  18. :doh: Bleed it yet? :fool: Rob L.
  19. A broken shroud would actually make you overheat, because of the misdirected flow... But, it shouldn't take you over an hour to get up to operating temp... Maybe like 10 minutes in this cold, but not an hour... I guess you could put some cardboard over part of the grill... You must have flushed, changed, and re-done the cooling system so many times its not OVER-efficient... :rotfl2: Is your heat at least finally hotter than the sun? Rob L.
  20. Well, we are going to the LKQ in Rockford... Kinda out of the way for us IL folk to drive out west, then up north... :nuts: Hooters? :dunno: Rob L.
  21. Its gnomes man... Darn gnomes. Rob L. :fs1:
  22. http://tiltedkilt.com/illinois/Rockford/index.html :( Rob L.
  23. Nevermind. Just talked to you on the phone.. T-stat is new, but still the first place I would look. It shouldn't open under 195, and I can't believe a 4.0L running is operating at 155 with a stuck closed thermostat. Rob L.
  24. You DID replace that thermostat that was stuck open, RIIIIIGHT? Rob L.
  25. We need to make an MJ version, with a LOT of tailgate action. Maybe as an ad for CC? :brows: Rob L.
