88mjmanche
Everything posted by 88mjmanche
ba10/5 to ax 15 swap NEED HELPPPPPP NOWWWWWW
88mjmanche replied to 88mjmanche's topic in MJ Tech: Modification and Repairs
correct the 96 transfercase has a 23 spline count and mine has a 21 spline count..... you are correct i want to keep the same drice shafts ALSO my speedo is cable driven not electric so theres a problem so i pulled out the 23 spline input very simple and I'm going to install it into my tcase problem solved..... but wil the ds stay the same i ask again and do i use the whole clutch assy with the ax15 -
i have an 88 mj cheif, short bed, 4 wheel drive, 4.0 with the ba10/5... i have the whole transmission/t case from a 96 cherokee... the bellhousing,clutch assy...master cylinder with line and external slave....... its attached to a 231...... yes i know the 96 231 has a 23 spline count as to my poopy 21 in the ba10... so no match up on that. here's one my questions can i take the input outa the 96 t case and put it in mine. and put it in my t case onto the ax15????? Question two the transmission cross member how far off is it i got a welder sooooooo i can fab up some stuff..... BUTTTTTT my biggest question is the rear drive shaft length is it going to stuff my slip yoke into my t case cause that would suckkkkkkkkkkkkkkkkkkkkkk
tooo late i ripped the axles out dana 30 aussi 3.07s dana 44 welded 3.07 700$ for sale in a month my friend might want them so i gave him a month
hers a pict what do you guys think and o yea I'm ripping it apart right now :yes: i just bought some dana 60s and some leafs and also 39.5 super swampers
yea the shock boots were put on about 3 hours prior to the event and the tool box tailgate was a last minute thing worked good though :dunno:
are those H I D lights if so sweetttttttt
can you say liberty wanabe i don't like it at all :ack:
well yea that would cause some shimmy and i had my passanger side U joint break caused some wobble also look at your stearing stablizer :thumbsup:
up it tells those toyota boys the name of a real truck
crack don't smoke itself imagine yourself at home no power raining like a beotch and a broken comanche you might lose it too and yes my labtop had power thats it
:agree: yup
the last time i used paypal i got jipped out of 90$ that pissed me off :headpop:
oooooooooooooooooo thank youuuuuuu :bowdown:
soooooooo i just calculated my MPH with a top speed calculator ofline and it told me i will have a top speed of 50 mph at 4000 rpm?????? i have a 88 with the 4.0 low output , i put in .79 as a 5th gear ratio ( I have a five speed ba10/5 ), 2.72 as a transfercase ratio, and 4.10 as axle gears. i also have 32 inch super swampers. my question is...... is the topspeed right at 4000 rpm and 5th gear i will go 50 mph ?????????????????????????????? :nuts:
could be track bar. the bar going from the frame to the axle
ring and pinion question
yea i have no clue what I'm doing i was just curious. in case i want to change out my carrier bearings -
how do you remove the bearings from the carrier and from the pinio??????????? :dunno: :dunno: :dunno: :dunno: :dunno: :drool: :drool: :drool: :drool: :drool:
manual transmission gearing
88mjmanche replied to bmaley79's topic in MJ Tech: DIY Projects and Write-Ups
yup so doesn't mine with my 32s and my AWESOME 3.07s yeaaaaaaaaaaa :clapping: :banana: :rotf: -
????? on 4.10 gears in a dana 44
ok i will take this advice :agree: the guy i know makes buggies for rock climbs and stuff custom longarms trusses gears...ext but yea you are right for 150$ i will buy new :thumbsup: -
ive asked a guy i know who does gears and he said he could do it :clapping: and they would work fine noise won't bother me i drive a jeep theres already too many noises :chillin: :yes: -
will these gears work http://cgi.ebay.com/ebaymotors/DANA-44-LOADED-CARRIER-WITH-RING-AND-PINION-4-09-4-10_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dLVIQ26ituQ3dUCIQ26otnQ3d2Q26poQ3dLVIQ26psQ3d63Q26clkidQ3d8906074609604589634QQ_trksidZp3286Q2em7QQcategoryZ33728QQihZ023QQitemZ360211698544 -
Why the hell knows, denver is a big place. If she is riding the bus in denver, no, she is not hot. this just made my day :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
i would put the link up but i don't want some else to buy them :yes: -
will they work
