comanche13
Everything posted by comanche13
  1. remember how i wanted to mount my bumper to the steering bolts well my friend dident do anything right so now i gotta do it myself can i make the mounts where the steering pump mounts then make anouher to go over that one and bolt to my bumper? so in other words i'll ave one plate thats just bolted to the frame then anouther one that goes over that one and then bolts to the regular 3 stock bolt holes in the bumper?
  2. remember how i wanted to mount my bumper to the steering bolts well my friend dident do anything right so now i gotta do it myself can i make the mounts where the steering pump mounts then make anouher to go over that one and bolt to my bumper? so in other words i'll ave one plate thats just bolted to the frame then anouther one that goes over that one and then bolts to the regular 3 stock bolt holes in the bumper?
  3. I'm cooking it tomo night needed to thaw it I'm marinating it in beer and some lousiana sauce then bbq it i'll let you guys now tomo :D
  4. i want a set for my 1990 comanche but will they work with the bench
  5. ok i know ive made alot of these post asking what kit is better but now I'm wondering is this rough country lift kit as good as the rubicon express lift kit?
  6. i was told it taste like grouse but i was also told if you don't soak it it anything it'll taste really bad... dono if its true or not
  7. picked up some alligator on the weekend and want to know a good recipe to cook it up?
  8. he said 2-3 weeks he'll start making them
  9. the pictures at the top are what there going to look like exept instead o cherokee there comanche and he's making the short bed rails first then long bed
  10. i talked to mike today I'm excited there exacly what ive been looking for =D
  11. how long do i have to get the money and order them for the special price?
  12. i know its the closed system i priced out a bottle here they want 114 for it which i think is expensive so i just fill it up every day or so
  13. well i did have a cut vacuum line but i repaired it and it now doesent just blow out defrost it seemed to just happen one day like it used to run really warmi just had the rad flushed when i bought the truck so i don't think it could be clogged i did also then have to drain it to put in my block heater but i took out the frost plug is it worth it to buy the mopar overflow tank or can i buy one of them cheaper ones?
  14. running at the quarter mark and 210 is the middle once in a while it will hit almost 210 but then drops i need a new overflow bottle mine spits coolant everywhere but there impossible to find!
  15. my truck won't blow hot air i dono if this is the same problem summermaine has or not but just wondering what it might be it sucks driving in -20 with no heat
  16. hey pete what front fenders are you using or did you just trim?
  17. SO THE 8.25 IS BETTER THEN AN 8.8? the 8.8 has 4.11 a posi and discs the 8.25 is i think 3.55 and drum
  18. i found a guy with a 1996 cherokee he is parting it has non vac axle in it will it be the bigger ujoints? also he has a 8.25 in anouther one is it worth buying? or would it be better to buy the 8.8 with disc's? what year is it the fenderflares don't go right under the truck? and what fender flares fit on the box of a short bed?
  19. when ordering the kit i was told to upgrade and buy the adgustable arms is this a good idea?
  20. i know one member has one i don't know how to spell his name sadly so i'll label him as he guy with the awesome write ups on his project but i was just wondering if i could get some photo's of a few get an idea of what mines going to look like
  21. me 4
  22. yes thank you very much
  23. man thats exactly what i want for mine i just have no interior at all its like driving a tin can right now haha
  24. i know theres alot of posts about mounting a front bumper but i have a few questions and i like lots of detailed pictures. ihave a front and rear bumper my friend made me up at work cause i don't have a welder but anyways the brakets that are attached to the fender in a triangle shape i see most people cut them do most people cut the fender its self also because i don't see any other way to tie into the steering bolts ? pictures would be great =)
  25. what lift kit are you using?
