comanche13
Everything posted by comanche13
Put a 8.8 in the rear to replace the dana 35 and upgrade to rear discs now the question I have about the bakes is can you bypass that load height sensor? Secondly my question about shocks is I installed a 5.5 lift came out to about 6 inches wondering if bilstein 5125 10" travel shocks will work with my lift if not what did you guys use and with installing these new shocks will I need bar pin eliminators or any other shock mounts? Also any suggestions for weld on shock mounts for the rear? Thanks Tim
I purchased a 1 ton steering upgrade (UTK) from JCR but have noticed the track bar bolt at the bottom is hitting on the tie rod when turned one way. Any ideas on what I could do with this? My thoughts right now are to just extend the stop bolts on the knuckles to prevent the tie rod from contacting the bolt. Thanks Tim
I just started to install my front Rubicon express control arms and they just don't look right. Is there suppose to be a gap like that between the bushings and the arms ears? I have added pictures for a better description.
Looking to buy fuse panel mine has had the biscuit. Will pay for shipping would prefer USPS. It is for a 1990 jeep comanche 4L 5 speed ax-15 thanks Tim
Bushwacker flat style flares on MJ?
comanche13 replied to comancheap's topic in MJ Tech: Modification and Repairs
bump -
Help on replacing clutch on ax15 transmission?
comanche13 replied to comanche13's topic in MJ Tech: Modification and Repairs
Planning on it also remachining the flywheel -
Just going to weld the splines to the yoke on SYE simple fix :yes:
I will be lifting jeep next weekend I have : Coil springs 5.5" Control arms drop brackets track bar and bracket drop pitman arm brake lines spring perches ubolts 3.25" coil spacers 1.75" sye 8.8 Is there anything I am missing? I don't know what type of u joints i need have a ax15 with a 231. I am ordering shocks for truck after it is lifted to see the outcome of how high the truck goes Thanks Tim
my comanche (nickname in progress)
comanche13 replied to comanche13's topic in Member Projects: Your Comanches
Well had a minor accident when offroading and ended up with some front end damage. This was in process and finished product Was very happy on look of hood when I painted it. -
look sweet man I am getting a new one across my back. Whats the golf cart indecent?
Just a few new pictures of the truck You will be all happy I replaced the balls with a moose also have been doing some work on truck I bled the clutch and fixed my front crank seal as well as replaced my balancer but new one will not fit. new one is on right here is the difference between the two new old and the reason I went with a new balancer -
project Old Rusty (new panel welded in)
comanche13 replied to MancheKid86's topic in Member Projects: Your Comanches
I own that same tool box set -
Harmonic Balancer will not go on.
just afraid it might mess up the crank because there has to be a reason its not going on -
I looked up part number and all numbers match for my 4 liter tomorrow I am going to go and get a longer bolt and see if I can pull the balancer onto the truck -
what type of problem I picked one up down at O'Reilly Auto Parts is it something I can fix easy need truck for tomorrow. -
I just changed seal and bought a new harmonic balancer but it will not go on it goes on about 1/4 so the bolt won't go in to even help pull it in. I have used a micrometer to make sure they where the same and everything checks out. I do not know why It will not go on any advice. Thanks Tim
What would you do if you were in my shoes??.. help
comanche13 replied to BeatMj's topic in MJ Tech: Modification and Repairs
The 8.8 never came in 3.09 if I remember correctly. -
Comanche of the Month, Feb 2011 - RYMANRPH's 1990
comanche13 replied to Automan2164's topic in Comanche of the Month (MJOTM)
looks great keep up the good job -
worst then rocky road?
