3
Everything posted by A-man930
anything can go wrong oil change
A-man930 replied to maddzz1's topic in MJ Tech: Modification and Repairs
Wish I would have seen that high flow housing and pump before I replaced everything yesterday :wall: Oh well, guess I'll do it on my new motor. -
New injectors installed... Very Happy!!
A-man930 replied to BLHTAZ's topic in MJ Tech: Modification and Repairs
Man, I had an LT1 for awhile :wall: Add this to the list of things I should've grabbed before they junked it. -
that's a renix motor in those first pics right? Where did you grab those? -
Well, as you can probably tell this was my virgin experience with a SFA setup... Where should I look for a different track bar since I'm lifted about. 4"???
You know, now that I think about it, I ended up detaching it at the axle... (sooo much easier) The limiting factor became the brake lines. It was a while ago, and I was taking out 3" lift springs, not stockers.
I had a hard time getting the track bar off the frame, you need a puller iirc... it was a HUGE pain with the trackbar attached, I had to rent a set of compressors.
inside of the MJ combo brake valve
A-man930 replied to Pete M's topic in MJ Tech: Modification and Repairs
So what is this common failure/problem with MJ brake systems??? I've experienced some funk with everything since I removed the right front calliper... do our brakes like to act up? -
Underbed spare carrier.
A-man930 replied to joshmillslane's topic in MJ Tech: Modification and Repairs
How big a tire are you guys squeezing under there? My spare is a 31x10.50 and it almost rests up against the exhaust... -
I've always wondered if you could get a truck box to work with one of these roll bars... It would probably have to be a custom one, has anyone seen this? More pics!
Replacing the Interior Lights -- (How I did it)
A-man930 replied to BLHTAZ's topic in MJ Tech: DIY Projects and Write-Ups
I need to do this! -
was anyone able to get the clips back on? I just ditched them and used silicone (on the bottom one anyways...)
turbo stroker debate: Renix v.s. HO
A-man930 replied to A-man930's topic in MJ Tech: Modification and Repairs
LEAD_NOT_FOLLOW: Your builds totally rock by the way... why a turbo? Because turbos are better :D Much more tuning flexibility, no paracytic loss to get boost, and it will spool right where I want it to when sized correctly. Besides, I've wanted to do a turbo something for a long time now, and the 4.0 would sport a hairdryer quite well. I will definately need lots of advice on my build as it progresses, you will hear from me, lol. -
I would not be able to answer that for you, I'm not really sure. I'm not really sure what exactly was done to the post '96 castings other than the addition of a stud girdle... Anyone? The original reason I asked if using a renix-era casting would be better was because of there already being provisoins for a knock sensor machined into the block. After reading a bit more I don't think I'll be using one regardless, now I'm making sure there isn't some big reason to avoid the renix block, as I'll have one lying around already. -
I have both, but I wish I had a factory service manual. I hear they rock, but I've had no experience with one.
Oh no doubt it will be pricey... but it does seem as if it will work. -
I realize this... With pistons that are meant for FI... http://www.hesco.us/shop.asp?action=det ... catId=7569 Among other things. Here's a build thread that I've been following: http://pirate4x4.com/forum/showthread.php?t=614289 -
After reading around for a bit, I've stumbled on some information regarding the non-HO 4.0L motors, that I previously hadn't seen. I had automatically assumed that the HO was a better choice for my intentions, but as it turns out, maybe not. First off, I will need a quick replacement for my current engine. Blow-by is bad, and I think I can hear the mains rattling at anything above 2 grand... I was looking for a HO to swap in, as I hear that it is a fairly easy transition from Renix to HO. I also intended to have the replacement motor's shortblock built turbo-ready stroker (although funds may not permit this quite yet :brickwall: ) Now comes the dilemma, I'm hearing that the pre-HO (Renix) 4.0 block is a better choice for strokers, and the only real advantage of the HO is the head/intake/exhaust/cam combo, which is interchangeable with any 4.0 or 4.2 anyways. This is supposedly because the Renix system utilizes a knock sensor (and since strokers like to ping...) My question now becomes: are there any issues/concerns that I should consider if I chose to use a Renix block for my turbo/stroker build? I would still have a variety of head castings/intakes/etc. to choose from, have the added insurance of a KS, and have one sitting in the garage ready to go... what to do!?
who has cut their fenders?
After takin' her out several times over the break, I've decided that putting the flares back on would really only give me something else to worry about breaking... Whiteshark, what did you put in place of the flares? I've seen that little black strip on cut fenders before, and I think it adds just enough of a "finished" look for me. Hopefully within the month I'll be tackling the rears :D -
Where do you guys get your parts?
Well I realize there isn't alot of MJ specific stuff out there, but where do you guys like to get your parts? -
Are there any suppliers that you guys swear by? I ordered my coil spacers from 4wd Hardware and they included their latest catalogue in the shipment, but it was all JK/TJ/YJ/CJ parts. I realize many of these are interchangable with XJ/MJ stuff, but it would be nice to have a dedicated XJ/MJ selection. I'm talking suspension, drivetrain, body, accesories... the whole bit. Who do I go to?
help with chevy lift on manche
A-man930 replied to project88mj's topic in MJ Tech: Modification and Repairs
Thanks! Just upgraded to 32s. I went with some 3/4" poly spacers from 4wd hardware. If I'd have known energy suspension provided new isolators I'd have gone that route. -
Well, I bit the bullet and trimmed 1.25" all the way around... it turned out way better than I expected 8)
