27
Everything posted by Eagle
I don't think it makes any difference what any of the sensors read. If the ECU isn't in closed loop mode, it ignores sensor input and operates on a pre-mapped fuel/air curve, which is programmed to be rich so the vehicle can operate during warm-up on cold days, when cold air is most dense.
You didn't flag "LOOP" as an issue, and that's the issue. It needs to be in closed loop for the O2 sensor and other inputs to control the air/fuel mix. That's related to the coolant temp sensor, because it won't switch into closed loop until the temperature is above 165 degrees.
Running hot & Over heating @ interstate speeds
Eagle replied to GreasemonkeySC's topic in MJ Tech: Modification and Repairs
Or 3. a lower (suction) radiator hose that collapses because it doesn't have the internal spring. -
I don't like to beat a dead horse, but we use words to communicate, so it's important that words are used to mean the same thing to everyone. The term "death wobble" has a specific meaning -- it refers to when BOTH front wheels are shaking so violently that it's almost impossible to control the vehicle, and the only way to stop it from shaking is to slow down to 5 MPH or less, or stop completely. If that's not what you are experiencing, you are not encountering death wobble and should not be asking advice to cure death wobble. It's not "DW, or whatever you want to call it." Either it's death wobble, or it's something else. If you can keep driving with the shaking, or speed up or slow down just a little bit and it goes away, you don't have death wobble. We're all here to help one another but it's difficult to diagnose problems remotely by Internet forum. When the wrong terms are used to describe tghe problem, it's impossible. [/rant mode]
I believe the ECU, which in the Renix years is located under the dashboard, is on the vehicle side of the C101, not the engine room side. I don't think you can just disconnect the engine room harness at the C101 and swap the part that's under the hood.
The 2.5L gives better gas mileage, but far less performance. However, as noted, replacing a 2.5L is far easier than doing a swap to a 4.0L. To change to a 4.0L you'll need a complete engine room wiring harness, a new ECU, a new radiator and radiator supports, a new transmission -- and probably a bunch of things I haven't thought of off the top of my head.
I discussed an ECU reflash with the dealership and they said there weren't any available.
TRANS fuse keeps blowing.
Eagle replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
I thought when the fuse blows the transmission no longer shifts. I know the diagnostic routine in the 1911 FSM for the AW4 says to remove the fuse and then drive the vehicle by shifting manually. Are you sure you getting shifting, or is it stuck in 4th gear and overworking the torque converter? -
Rewiring & Aftermarket ECU
Eagle replied to LittleBoJeep88's topic in MJ Tech: Modification and Repairs
I am not aware on any GM 4.0L engine that was ever used in any Jeep vehicle. What Jeep vehicle ever came with a 4-liter, 6-cylinder GM engine? -
WHOA! The Jeep 4.0L engine is NOT a GM engine. -
Not looking to tune anything. I'm looking to eliminate a driveability issue.
Probably not so odd. The factory really didn't want to build any 5-speed manuals in model year 2000. When I went into the dealer to order an XJ to replace the [bleep] [bleep] [bleep] '99 WJ Grand Cherokee, the factory wasn't taking any orders for 4.0L manuals, so I ordered a Classic with automatic and Selec-Trac. This was in October of 1999, and the vehicle showed up in November. That one was turned over to my wife when I married her in 2003. Somewhere along about January of 2000 I was in the parts department picking up something, and the sales manager wandered through. He knew I had wanted a 5-speed, so he mentioned that the factory was accepting orders for 5-speeds. 'But I guess you don't need one now," he said. "Wrong," says I, "let's fill out an order." So we did. And then I waited ... and waited ... and waited some more ... and waited still more. Whenever I checked, the order was still sitting there but no build date had been assigned. Jim, the sales manager kept asking if I wanted to cancel the order, and I kept on saying no. So we waited ... and waited ... and waited. Anf then one day around late April, if I recall correctly, he said they had a build date. It looks like they waited until the very tail end of the 2000 model run and then did a short run of all the 5-speed orders. I could look up the date, but I think mine finally arrived in June. So it wouldn't surprise me if it's a bit of a mongrel, built from whatever parts they happened to have on hand. Where did you find that info? That part number doesn't show up in my parts manual.
Got it: 56041 668AF Which is interesting, because that part number doesn't appear in my 2000 XJ parts manual. It also doesn't appear in the 1999 or 2001 XJ parts manual.
Check my work!!! Suspension.
All I can make out at night, with a flashlight and inspection mirror, is 956041. But they all start with that, so I'll have to look again tomorrow.
Front brake question, HVAC question.....
To be honest, I very likely won't ever finish it. Too many things have gone wrong in life since the project began. But it's still a possibility, which is why I'm not releasing any excerpts I share into the public domain. -
Correct on the change between 1989 and 1990, but it's not just the calipers. There are several permutations and combinations that all have to match up. The floowing is from the book I started to write several years ago. It is copyrighted, and by posting it here I do NOT grant permission for anyone to reproduce it or to distribute it. - - - - - - - - - - - - - - - In general, the parts to be concerned with in keeping the front brakes compatible are the steering knuckles, the hub/bearing assemblies, the rotors, and the calipers. (There is a more complete enumeration of the interrelationship of these parts in Chapter 6, Axles.) Only two steering knuckle designs were used: 1984 through 1989, and 1990 through 2001. Left and right side knuckles are different part numbers within each group. Three different hub/bearing units were used. The hub/bearing units are the same for both sides of the vehicle. The different years for hub/bearing assemblies were: 1984 through 1989; 1990 through mid-1999 (composite rotors); and late-1999 through 2001 (cast rotors). Three rotor types were used: 1984 through 1989; 1990 through mid-1999 (composite); and late-1999 through 2001 (cast). Only two caliper types were used: 1984 through 1989, and 1990 through 2001. Left and right side calipers are different part numbers within each group. -
Not true. We want zero toe-in -- when the vehicle is rolling down the road. We set it for slightly more because once the tires start rolling and encounter road resistance, that resistance takes up all the slop in every tie rod and joint in the steering mechanism. Way back when I was in my teens (around the time they signed the Magna Carta), the good front end shop in town used a spring loaded spreader bar that fit between the leading edges of the two front tires to force them out, simulating the real-world rolling condition. Otherwise, if we set it for zero in the driveway, on the road that built-in slop will allow the tires to splay out, and then we have toe-out -- which is what we DON'T want. Yes, tire size affects toe-in, because what we're really looking for is an angular measurement. In the old days, it was just easier to express and measure it in inches. IIRC, the 1988 factory service manual for the XJ and MJ give the alignment specs in inches (fractions). The FSM for my 2000 XJ gives the specs in degrees, which are independent of tire size. But if we're doing it at home, we're not set up to measure angles so we use a tape measure. And if we're doing it with a tape measure, the larger the tires, the greater difference between the front and rear sides of the tires for the same angle. I've never rolled on anything larger than 31x10.50s and I still regard 1/8" of toe-in as the maximum I want to see. When I'm doing a shade tree alignment, each time I make an adjustment to the toe I roll the vehicle back a car length, then roll it forward again. This allows the tires to "sqirm" into the new alignment, so my measurement isn't fighting sidewall tension created by making an adjustment while the tread contact patch is firmly planted on Terra firma. -
Spacers in the rear have nothing to do with front toe-in, and you don't add or subtract anything based on the rear. You measure the distance between the centerline of the front tires at the front, and again at the rear of the front tires. If the number from the front of the tires is larger, you have toe-out; if the number at the rear of the tires is larger, you have toe-in. The theortical ideal is zero, but in the real world you should aim for about 1/16" with 1/8" being the max. You do NOT want toe-out. -
Definitely not rusted away. It only has 41,000 miles on it, and has spent most of its like garaged. And this problem has been there since I drove it home from the dealership, new.
Thanks but neither suggestion fits the symptoms. This is basically that the slightest lifting of pressure on the accelerator peddle is like shutting the engine off -- completely.
It happens at pretty much all RPM ranges.
My foot is on the accelerator peddle, not the slip yoke. I know what you're referring to, my late, unlamented '99 WJ had that. This it totally different.
I have one of the extremely rare 2000 XJs with a 4.0L engine and 5-speed. I believe mine is the only one in Connecticut, and I've been told it's one of only two in all of New England. I've had a problem since it was new, and it's getting aggravating enough that I'd like to fix it. I've been driving standard transmissions for over 60 years, and I've always considered myself to be a "smooth" driver. I don't slam shifts, my clutches last forever, and my passengers don't complain that their heads are being snapped off at the neck by the way I drive. Except ... in the 2000 XJ. It's impossble to drive smoothly. Example: Say I'm on a level road at 55 MPH. I come to a slight downgrade and speed increases, so I want o ease off the throttle just a bit to maintain 55 MPH. Can't do it. No matter how gently I try to ease up on the peddle, as soon as I start it's like the engine shuts off, the driveline lets out a loud clunk, and I'm slowing down. So now I need to apply juuuuust a little bit more throttle to get back up to 55 MPH. Nope -- same thing. No matter how gently I try to squeeze on the throttle, it comes in with a bang and a lurch. It's very annoying. I had the dealership look at it a couple of times while it was under warranty and they couldn't find anything wrong, sio I've been living with it. But it's not right. I want to fix it. I thought it might be the TPS, but the 2000 XJ FSM doesn't have any information about adjusting the TPS. They tell me how to replace it, but no mention of an adjustment. Does anyone know if it can be adjusted? If so, how?
HVAC mode actuator location
That's the problem, then. Under light throttkle the engine has enough vacuum to hold the actuator doors where you set them but when you accelerate or go up an incline, as you know the throttle opens and the engine vacuum drops. The canister is a vacuum reservoir to maintain vacuum under those conditions. You can get a canister from any wrecked XJ. There are two types -- the ones with cruise control have two chambers, one for the HVAC and the other for the cruise control. If your truck doesn't have cruise, you can use either type.
