M2 CARBINE Posted June 3, 2008 Posted June 3, 2008 What's the best way to trim fenders on a MJ? planing on putting on some TJ flares.
chicofuentes0224 Posted June 3, 2008 Posted June 3, 2008 I've been using a Dremmel with a heavy duty cutoff wheel. They don't last long but I get a more precise cut than with a reciprocating saw and blade.
JOMJ87 Posted June 3, 2008 Posted June 3, 2008 Air body saw. MY favorite tool on the jeep. I would place the flares on the side where you want them to sit and trace it onto the fender. TJ flares have a lip on them you have to cut off as well so they flush mount. Take your time and good luck. 8) Cole
LEAD_NOT_FOLLOW Posted June 3, 2008 Posted June 3, 2008 Here is a recent thread about it on GLXJ as the same subject recently came up. http://greatlakesxj.activeboard.com/ind ... D=17770234 I run the TJ flares on the rear of my MJ and I have to say it was the most annoying/frustrating part of my build. They are a PAIN to get them to look decent. Lots of trimming on the flare itself and they don't like to contour the body of the MJ rear very good. As for trimming, I did the same thing we do when we trim on the XJ's, I cut and fold. Let me see if I can dig up some pics.... Before (you can see it's been folded over itself). After (I only ran them to cover up the rust hole shown above.) I had planned on running rear TJ flares on the front but after so much cussing at doing the rears I decided I could deal with the factory flares for awhile. Maybe I'll get to doing them one of these days... :roll:
TNT Posted June 4, 2008 Posted June 4, 2008 Stock flares will fit with some work and look good. Mild with 33" tires (up to bodyline) Filled gap Inner fender liner Or wild (above bodyline) with 33" tires (in process, it will have a wheel liner) Image Not Found Image Not Found Image Not Found Image Not Found There are no gaps they are complete filled and looks good. Here are some pictures of the both style flares showing how it is filled. Raised to the bodyline Mounted Image Not Found How the gap was filled Image Not Found Side views Image Not Found Image Not Found Raised above the bodyline Mounted Image Not Found How the gap was raised Image Not Found Side views Image Not Found Image Not Found Comparison Image Not Found Image Not Found I have raised my flares as much as possible, as I have posted before. Here is a picture of the inner fender after raising the flares with 33" tires. Image Not Found I cut the front of the inner fender for a dramatic increase in room. My goal is to get as much uptravel as possible as part of my build. I still need to do some more welding, then clean up and paint it. Here is a picture looking straight down from under the hood. Image Not Found Image Not Found Here is a picture the inner fender. I gained 4" or more of clearance. The difference is dramatic. Image Not Found There is now more room in front the tire then from the rear or above. I should be able to stuff the tire about 3" more and still be able to turn from lock to lock. As part of my build the front axle will be moved forward 2"-3". I will be adding an inner wheelwell liner. Here is the cut and raised rear fenders/flares my '95 I parted out. 5" of lift with 33" tires. Image Not Found
M2 CARBINE Posted June 7, 2008 Author Posted June 7, 2008 well the front was easy just got to add the TJ Flares But the rear was something esle I cut about 2 in off and know i gotta weld the rear back togather since the two peices of bed came apart. What kind of brackets or hardware you some you guys use I'm going to use stainles steel nuts and bolts
DirtyComanche Posted June 7, 2008 Posted June 7, 2008 TNT, have you test stuffed the suspension with the front cut like that? Does it allow for much more uptravel?
