Vacuum actuator on 1991 front axle
I'm turning my 2wd into a 4wd with a 242 transfer case. I got an axle cheap that is in good shape, but it has the actuator and the 242 doesn't have vacuum lines to it. I was going to just stick some washers in there to permanently lock it, but would like to have 2 low. So I hooked up an old fish tank air pump to it and it shifts fine. (Not in the truck at the moment). The question is: Does the actuator need constant air pressure to stay locked or will it stay in position once it is shifted? Seems to need air through the other nozzle to disengage, but it isn't under much pressure or moving very fast when I turn it by hand.
Thanks, brian
Lock it and forget about it. You will still have 2 lo because it's the t-case that decides what range your in, not the axle. And yeah 242's all came with non-CAD axles, thus not having vacuum lines run to it.
:cheers:
I think he's refering to having the TC in 4low (thus the low range) but not having the front axle engaged. If he perm. locked it he would loose that function.
If my memory serves me correct the vac. disco does require constant vac. pressure to stay over to keep it locked. It's not much but I think it does need the constant pressure. The other line does help push it the other way, but I think thats simply to make sure it does disengage.
Thanks, brian
You can use a vaccum storage can like those the racers use to store vaccumized air when their cam is too big. You will need 2 check valves and a Selec-Trac switch or similar from a vehicle with Selec-Trac. I know AMC Eagles had them in the dash and I can't remember which car had them on the console. A Talon? They just switch left to right for 2wd and 4wd. Run the line to the vaccum can from the mainfold via a Tee, then from the vaccum can to the center vaccum port on the Selec-Trac switch. Run Lines from the switch to your axle actuator. 2wd position vaccum port connects to the small diameter canister side of the actuator, 4wd position vaccum port connects to the big diameter canister. You will only have a basic engagement system but you could use another check valve and a 4wd vaccum switch from an XJ or MJ for a light if you wanted.
Better check the gearing in the front axle because if they are different they will fight each other in four wheel drive. plus the two wheel drive rear is geared different. i started with a 86 and a 90 4x4 and transfered the 90 drivetrain and dash to the 2x4 to make it 4x4
Yeah, like this. I've got the switch, and it's on the to-do list.....I've got mine shimmed over with washers currently. Jerry (tjbliley) is in the process of rigging his up with air solenoids, should be pretty slick when he's done.
Jeff
Image Not Found
maybe I'm miss understanding something here. But why don't you just do away with the vaccum disconnect all together. I did not do this write up but i something that i found online, and was quicker than typing something out...LOL
here is alittle write up on it....
I have TJ Dana 30 shafts in my YJ. The parts you need to do this in a YJ are as follows:
-both inner and outer axles out of a TJ.
-a block off plate for the axle disconnect
-two axle seals
-diff fluid to replace the stuff you drain during the install
When putting TJ shafts into a YJ, you need to put a plate in place of the vacuum switch assembly doo hickey that is there now and seat two seals (one right by the diff and the other on the outboard of the disconnect cavity). I had these parts as part of a kit that come with Warn high strength axles. Guys who buy those shafts for their TJs don't use those parts and a fellow jeeper was very kind enough to send them to me. The Warn part numbers are:
Inner seal - 37897
Outer seal - 60006
Block off plate - 39147
Note from Stu: I pulled these part numbers off of a reliable forum, however, I've not verified them:
Inner seal - Chicago Rawhide CR11343
Outer seal - Spicer 46470
The instructions that came with it are pretty good. Warn's customer service number is 1-888-722-6730
Here is a picture of the parts: yjconvert1ik0.jpg
Here are some off-hand abbreviated instructions paraphrased from Warn's instructions (which are pretty darn good if you are getting the seals from them then make sure the instructions come too) and from the answers I got from fellow jeepers to my own questions when I planned out this modification.
1. Go to Stu's website and follow the instructions on how to remove everything outside the steering knuckles. ie.. brakes, rotors, tires and he even includes bolt sizes and locations. He did a great job as usual and I won't even attempt to top his detailed write-up. Go to Stu's kick @$$ Dana 30 axle shaft removal write-up.
2. By now you have the shafts ready to be removed, if you haven't already done so then take out the stock shafts. You will need to remove the vacuum shift motor housing to get out the long side axle. Looking over my FSM it is a pretty obvious process and they have some good illustrations. It starts on page 2-27. Pretty much remove the four bolts holding on the vacuum shift motor housing and gut it of the shift collar fork and anything else there, you will have to have that new outer seal to install in place of the factory stuff. Disconnect the wires going to the shift motor housing and plug the two vacuum lines. Zip-tie anything left of the harness safely under the hood. I really suggest getting a factory service manual if you don't already have one, it is a must buy item for any jeep owner. I bought mine direct from DC at on the internet at www.techauthority.com The phone number to call is 1-800-890-4038 if you feel talkative.
3. You will need to remove the carrier from your differential in order to place one of the seals. This means getting your tie rod out of the way. Here is a quote from a smart dude named Robert:
You do not need to use a pickle fork to remove the tie rod. A decent flat bottomed hammer of fair size will work better, a bronze mallet works best. If you haven't removed them in awhile, hit them with some penetrating oil (not WD) and then use the hammer on the front of the knuckle where the tie rod mounts. Do not hit the tie rod or the tie rod end and leave the castle nut part way on to capture the rod when it falls out of the tapered hole. A pickle fork will only serve to ruin the TRE boots.
4. Once you have swung the tie rod out of the way you have easy access to the differential. Drain the fluid and open it up. I leave one bolt partially screwed in at the top so that the cover won't go splashing into the pan of gear oil when I break the gasket seal. Once it's drained completely I remove the last bolt and the cover.
5. Next is to remove the carrier (make sure you have the axles removed before you pull the carrier or else it won't come out ) Watch what you are doing and be sure to use a grease pencil or something to mark exactly how you took the carrier out. Here is a quote from another smart dude named Mark:
The bearing and bearing caps must be reinstalled in the same location and position as original. The D30 should have the shims inboard of the bearings, so they will not go anywhere. IF you have regeared, there is a possibility that the installer may have put some shims outboard to cut corners, so keep an eye on it if that's the case.
That's really all that's to it.
6. Time to put the seals in now. As per the Warn instructions you can use a 1 3/8" socket or appropriately sized wood block to seat the inner seal with blows from a hammer. This is the seal that goes right beside the carrier. Make sure it goes in square and is fully seated, I would also pre-oil the edges with some clean fluid to make sure they don't get messed up as the shaft is reinstalled.
7. The Warn instructions show two ways of seating the outer seal. It goes in the vacuum shift motor area on the side closest to the passenger side tire. I drew a picture of how I plan on installing it and of the basic assembly of the this modification.
8. After both seals are installed then reinstall the carrier being sure to put it back how you marked it before. You do not want to screw up the gear installation.
9. Now slide in the new TJ axles. Be sure to not catch or drag on the seals or you may damage them.
10. Now install the block off plate for the vacuum motor housing. I am going to use some RTV to make sure its sealed tight against the axle housing. Now install the differential cover and refill the diff with the proper gear oil. The manual says to use 75 weight gear lube.
11. Now reverse Stu's instructions to put back all of the components outboard of the steering knuckles.
The above was a copy and paste from my own previous attempt at typing up these directions from my experience of this install on my 1994 YJ for another Jeeper.
Some notes to add are:
- The brake caliper mounting bolts are only supposed to be torqued to 7ft-lbs. Be careful with that torque wrench and make sure that there is no metal shards in the threads to strip out the hole in the outer steering knuckle.
- The factory hub bearing units can pop in half if you try hard enough. I was using a two jawed puller to pull mine off the stub axles and POW it popped in half. I tapped it back together gently and now it works fine but in the end it took a chisel acting as a wedge between the knuckle and the hub to get it off.
- Make sure there is no contact between the dust shield and the rotor. There wasn't any on mine at first but after a test drive it was scraping like crazy and I had to get the rotor turned. Apparently I bent the dust shield a little when I was wrestling with the other half of the hub.
- My diff carrier was stubbornly staying put so I took a three foot long pry bar and some sprayed some PB blaster on the bearings and it came out slowly. It turns out I was able to get it out without pulling off the tie rod by turning the carrier on its side. Getting it back in wasn't too bad, I used a big rubber mallet to make sure I didn't ding up the teeth of the ring gear at all.
- I removed the entire vacuum harness. It had 4 vacuum lines going to the transfer case and one going to the intake manifold. I used appropriately sized screws from my junk box to plug the holes. The switch unplugged neatly from the disconnect switch vacuum assembly and I taped that up and zip tied it up by the battery.
- It might help you out to borrow or buy a seal installing kit from someone. It is supposed to have die that make it much easier to seat the seals correctly. I had to make do with the washers and sockets I had around the garage and it sure took me longer.
- If you don't have one already you need a 36mm socket to take off the big nuts that hold your axles to your hub.
- You may have to get your front driveshaft balanced. Mine was bent from when I was high centered before I got a suspension lift. This axle modification brought the damage to my attention as I was getting a new vibration because the front driveshaft now spins all the time like on a TJ.
That is about everything I can think of right now. Feel free to email me if you have any questions. Ty
Update: 02/02/2007
Here are some part numbers to the seal that fits in the passenger side of the axle tube right at the differential. Please bear in mind that I used the seal that Warn sent and haven't ordered a seal using these numbers. They were kindly provided to me by other guys who have emailed me after they did the axle shaft swap.
Chicago Rawhide Part No: CR-11343
National Part No: 471763
Quadratec Part No: 52420.12
The axle shaft change is the way to go. Yukon sells a kit for about $40 with a block off plate and the needed seal and then all you need is a one piece axle shaft. Get the axle out of a '96 or later Jeep so you get the stronger u-joint.
I think the point is that he can use 2wd in low range without applying power to the front wheels (as long as their is no locker) since the vac. disco can be disconnected. It's much cheaper doing it the way he's talking above than running the Tera-Low kit and having to tear apart the t-case.
OR
Maybe I'm just miss-understanding the original post...
The solid axle would be more reliable, but that's more cost and work. So I figured I'd just hook up the aquarium pump and a switch since I have all this already and it will be a separate system and easier to trouble shoot if I have a problem and still be able to connect and disconnect. The hose size from the pump is even the right size.
Yea...you can achieve your goal of having 2L by using a cable actuator as well. Right now I have the Posi-Loc, but you can make your own from a bycycle shift cable and just lock and unlock it manually. Cost about $20 for all you need. ;)
Why use an aquarium pump instead of engine vacuum? Or are you running a diesel engine?
The factory setup uses it off of the transfer case with the NP231. A NP242 never came with a vac. disco axle and does not have any vacuum setup on it to control the vac. disco on the axle.
What I mean is the engine creates vacuum. Why not run a vacuum line from the engine to the dash switch to the disco, instead of using the aquarium air pump.
There's a 4 liter 6 cylinder vacuum source 3 feet in front of you, so why use an external pump?
It took a couple of days before the light finally came on. :fool:
I understand what he is after now and your totally correct. :D
I agree with the suggestion to just use the engines vac system with the switch. Just grab the vacuum lines for axle and what would have been used for a 231 and put your switch in its place.(not littorally)
:cheers:
I'm going to use the vacuum now, but does anyone know where to find a switch for the dash? I'm in seattle. Do any parts stores sell something that would work or do I get to search junkyards for an old eagle?
Some of the grand waggys had it as well... look in the glove box.
CW
ok here's what i have done in the past
1 ful tank transfer switch from 1985 chevy p/u with dual tanks
1 switch of what ever you chose
12 volt power to the switch
switch turns on and off the transfer swtich
thus you now have 4wd as an option by fliping the switch
i ran this 4 years in my yj with a lock right in the front on hard roack it was at times hard to turn so off with the switch 1 wheel drive turn and back in
also on a yj the yellow hose is 4wd and green will get you 2wd
you need constant vac to pefrom the act so if you want 2wd vacume to the green hose dose it
I found a switch at the junkyard from a wagoneer. Even has lights for 2wd and 4wd. Sure it is that beautiful peanut butter/turd brown from the 70's but that's why they invented spray paint. Thanks for the tip. Now I just have to figure out where to mount it.
