trippnk Posted April 29, 2008 Share Posted April 29, 2008 Are 4.5in TJ front coils the same height as 4.5in XJ coils? I got a cheap set of Rubicon Express 4.5in TJ coils and when I put them under my MJ even with a 2in spacer it is considerably lower than the rear which we measured 5.5 in of lift after SOA. Link to comment Share on other sites More sharing options...
Pete M Posted April 29, 2008 Share Posted April 29, 2008 No. If I remember right, TJ coils will give MJ/XJs less lift than TJs. Link to comment Share on other sites More sharing options...
trippnk Posted April 29, 2008 Author Share Posted April 29, 2008 Crap, guess I have to look for some new coils LOL Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 29, 2008 Share Posted April 29, 2008 No. If I remember right, TJ coils will give MJ/XJs less lift than TJs. This is what I remember as well. TJ coil's are shorter for the same lift as XJ/MJ coils are. CW Link to comment Share on other sites More sharing options...
xjcrazy09 Posted April 29, 2008 Share Posted April 29, 2008 Tjs are shorter, but aren't the Grand Cherokee Coils larger? Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 3, 2008 Share Posted June 3, 2008 ZJ are larger, stock coils are like an inch taller and give a inch of lift on a XJ/MJ. Link to comment Share on other sites More sharing options...
voltageyz0 Posted June 4, 2008 Share Posted June 4, 2008 if you get grand cherokee v8 coils you will get 2'' Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 4, 2008 Share Posted June 4, 2008 TJs are about an inch lower, or so. Link to comment Share on other sites More sharing options...
