Super_MJ Posted February 20, 2008 Share Posted February 20, 2008 I got the truck with stock Cherokee axles and on the rear axle there is an unknown plug, anyone knows what is it? Link to comment Share on other sites More sharing options...
UNL1MTD Posted February 20, 2008 Share Posted February 20, 2008 have you popped the rear diff cover to see if there is anything other than spider gears inside? I've never seen that before, but maybe its an aftermarket plug for a locker or another kind of traction aid? Link to comment Share on other sites More sharing options...
Super_MJ Posted February 20, 2008 Author Share Posted February 20, 2008 Didn't open anything yet. If it's a locker, shouldn't it have some king of plug for air? Link to comment Share on other sites More sharing options...
mjeff87 Posted February 20, 2008 Share Posted February 20, 2008 just a guess, but the XJ that came out of might have had that "sentry" panel in the dash, and that might be a sensor of sorts for rear axle fluid level (?????) Is it just attached to the axle, or does the wiring actually go into the diff? Jeff Link to comment Share on other sites More sharing options...
mfpdm Posted February 20, 2008 Share Posted February 20, 2008 just a guess, but the XJ that came out of might have had that "sentry" panel in the dash, and that might be a sensor of sorts for rear axle fluid level (?????) Is it just attached to the axle, or does the wiring actually go into the diff? Jeff Hhmmm. I was going to say locker until you brought that up. It does appear to be a factory looking setup. But if both axles came from the same xj, it should have one on the front as well. The sentry system monitored all fluid levels or temps. Forget which but it was only availible on waggys, I think. Besides being next to impossible to find the sentry dash piece, the actual sensors are even harder to find. Will be courious to see how this comes out. Edit: If that cover will come off, you would be able to tell real quick. If it is the sentry system, it should just be screwed into the housing.(kinda like yor temp sensors on the engine block) :popcorn: Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted February 20, 2008 Share Posted February 20, 2008 axle lube sentry sensor Link to comment Share on other sites More sharing options...
Super_MJ Posted February 21, 2008 Author Share Posted February 21, 2008 I took the cover off and there are two wires going into the diff, so I guess it is the sensor. Thanks all. Link to comment Share on other sites More sharing options...
mfpdm Posted February 21, 2008 Share Posted February 21, 2008 I took the cover off and there are two wires going into the diff, so I guess it is the sensor. Thanks all. That is a rare bird you have there. The first one I've ever seen. So does the front have one as well? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 21, 2008 Share Posted February 21, 2008 I took the cover off and there are two wires going into the diff, so I guess it is the sensor. Thanks all. Unless you have the Sentinel panel monitor in the dash, me thinks you should pull that sensor and seal it off with a NPT plug. Might prevent future leaks. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted February 21, 2008 Share Posted February 21, 2008 That is indeed the XJ Waggy Sent sensor. The front should have it too, but if not then the front was never swapped. My 91 was going to get a set of Waggy axles with those on em since I have the Sent in the MJ. I decided against it since I didn't feel like doing the swap for something that will mainly just be for show. Alex Link to comment Share on other sites More sharing options...
Super_MJ Posted February 21, 2008 Author Share Posted February 21, 2008 So does the front have one as well? I guess the front "had" one ;) Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 21, 2008 Share Posted February 21, 2008 Yep...I would be removing those and putting a plug in there. With my luck, I would hit a rock, break them off and lose all the fluid. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 21, 2008 Share Posted February 21, 2008 Yep...I would be removing those and putting a plug in there. With my luck, I would hit a rock, break them off and lose all the fluid. VERY GOOD advice man!!! CW Link to comment Share on other sites More sharing options...
mfpdm Posted February 21, 2008 Share Posted February 21, 2008 That is indeed the XJ Waggy Sent sensor. The front should have it too, but if not then the front was never swapped. My 91 was going to get a set of Waggy axles with those on em since I have the Sent in the MJ. I decided against it since I didn't feel like doing the swap for something that will mainly just be for show. Alex Do you have any of the sentry wired up or is it just in there? If Super_MJ pulls them out you ought to see if he'll send them to you. Even if you don't install them, having them, plus the dash unit, could be worth something someday. If anything an interesting conversation piece. :D :cheers: Link to comment Share on other sites More sharing options...
GirsMJ86 Posted February 22, 2008 Share Posted February 22, 2008 Do you have any of the sentry wired up or is it just in there? If Super_MJ pulls them out you ought to see if he'll send them to you. Even if you don't install them, having them, plus the dash unit, could be worth something someday. If anything an interesting conversation piece. :D :cheers: Some of it is wired, wiper fluid level and a few other easy to install sensors like that. If he wasn't clear across the nation and getting rid of the entire axle it would work. Not sure but I think trying to put the just sensors in a normal axle wouldn't be a smart move. Someday I will find another Waggy XJ with em still and swap em out if I still have the 91. Alex Link to comment Share on other sites More sharing options...
Super_MJ Posted February 22, 2008 Author Share Posted February 22, 2008 Do you have any of the sentry wired up or is it just in there? If Super_MJ pulls them out you ought to see if he'll send them to you. Even if you don't install them, having them, plus the dash unit, could be worth something someday. If anything an interesting conversation piece. :D :cheers: Some of it is wired, wiper fluid level and a few other easy to install sensors like that. If he wasn't clear across the nation and getting rid of the entire axle it would work. Not sure but I think trying to put the just sensors in a normal axle wouldn't be a smart move. Someday I will find another Waggy XJ with em still and swap em out if I still have the 91. Alex Or, you might just take your Sent off and send my way ... j\k Don't think I'm going to mess with it for the time being. Link to comment Share on other sites More sharing options...
