Ok, so after wheeling a lot, my steering seems to be messed up
Its still functional, but it feels loose, and very unresponsive, and sometimes makes a loud popping noise, sometimes a soft popping noise, sometimes no popping nopise. Thinking it might be the CV joints? At first i figured something needed to be tightened, but couldnt find anything to tighten :roll:
Anyone have any idea what could be going on?
check your trackbar at the axle end...probably the bolt backed off
X2 ... A loose track bar is very often the cause of this issue. You may need a new one as well if the bushing is worn out.
Just went outside to check it out, nothing on the sway bar seemed loose, not sure how tight its supposed to be? Had someone turn the steering back and fourth while i was underneath it, popping noise is gone. I'm sure it will be back though, does that change the situation at all? :nuts:
No, the trackbar, not the swaybar. Look at the end link while someone turns the wheel back and forth quickly. You'll see a lot of movement if it's worn out.
Check the small ujoints in the steering colunm shaft. I had an xj that did the same thing and those joints were bad. Also check the track bar mount on your frame. The bolts on my xj's backed out and it made the steering very loose.
ok this is weird
went outside today, steering seems tighter, no noise, drove around for 20 minutes, took it in the mud, no popping noise whatsoever. Maybe the temperature has something to do with this? It was a little warmer today (like 35 degrees?)
Not really sure whats going on, everything seems tight
