voltageyz0 Posted February 18, 2008 Posted February 18, 2008 i went today and looked at a comanche and the drivers side door was sagging about a half an inch. dose anyone know wats wrong?
LEAD_NOT_FOLLOW Posted February 18, 2008 Posted February 18, 2008 http://www.greatlakesxj.com/tech/door_hinge_repair.pdf
Eagle Posted February 18, 2008 Posted February 18, 2008 Last I knew (a couple of years ago) there were still lots of those hinge repair kits in the parts system. The same repair also applied to XJs, especially the 2-doors with the wider, heavier doors. But the XJ has been out of production for several years, so who knows? Check your dealership parts gurus to see if they can still order the kits. If not, there are otjer ways to reinforce the door post and reattached the hinge, but it requires a good body man/welder to do it right.
MiNi Beast Posted February 19, 2008 Posted February 19, 2008 JB Weld Pull the door and add 1/8'' steel plate behaind it and weld up and take the shims out.
djag12 Posted February 20, 2008 Posted February 20, 2008 Hmmmm. I always thought my door hinges had the worst welds. Now I know why. I actually thought they were re-welded. They look like they are going to fall off but don't sag. Thanks for the info.
