4x4 not engaging
:cry: Well.... not the best day to find out my 4wheel drive does not want to engage. A freak windy snow storm hit us today. It was only forecasted as a wind advisory, but snow came down with it. Argh, after slipin and sliding I decided I would put it in 4wheel drive, so I pulled it over and went 4hi. hmmm started off sliding from my stopping place. ok I thought maybe it needed to engage and I would be on my way. Ok stopped slipping and I was off until I needed to get up a slight incline. That's when I realized I had no 4wheel drive and it snowed harder until I gave up and went home. Not familiar with the 4x4 sytem on the JEEP seeing as I'm new to the Comanche but have owned a couple cherokees before my tinkering really kicked in. Any easy fixes or trouble shooting?
Chances are good that it's a problem with the CAD or Central Axle Disconnect. A simple way to eliminate this as a problem is to pull off the CAD cover on the front axle and use washers to keep the fork shifted all the time. Doing this is in no way detrimental to anything. Jeep eventually did away with the stupid design altogether.
Image Not Found
It's the blob of cast steel on the passenger's side of the diff with all the vacuum lines coming out of it.
