8) okay pulled out the old guage cluster and popped in the other, I stuck with the cable type) matched up just fine. changed the oil pressure sensor and the temp sensor. hmmmm nothin really working, just the speedo, back lights, turn signal, brights. unplugged it and noticed different pin locations for the wire plugs. So could it possibly be this will not work as easily as was described on a thread I found here LOL. I'll include a few pics to show my problems.
On the interior swap, not too bad, swapped out the upper and lower dash and trim parts. Looks real good, made sure I got the ones with some wood trim. have not done the seats yet, got cold again before I got that part done. So here's the pics on the cluster swap.
the top one is the new one, the bottom is what my 87 comanche had in it both were 4.0 not sure on the year but I want to say 88-90 atlaeast. if I need to run out to u-pick it I could and probably cut the plugs off to know what goes where if I ned to re-pin them. ok now a couple close ups
old one
new one
sorry if they are fuzzy, only had my phone handy
hmmmmany help out there would be appreciated
