I can't get a straight answer about how this swaps out from anyone. on the left is what i took out of the new t-case witch incudes a 35 tooth gear and on the right is what was in my factory t-case that my mechanical speedo plugged in to and that includes a 29 tooth gear.
what do i do and or need to buy to get my cable to plug into my new case?
What kind of case was in there? Was it a 207? If it was you may need a new gear for the 231. You should be able to swap the gear into the holder and put it in and it should work. The drive gear in the case is about an inch and a half long I think so it should still engage the speedo gear.
simply put the one that used to be in your truck into the new transfercase.
as a quick answer, those are both from a 231 or 242 (or even newer 207) and are fully interchangeable. the one has a longer shaft because it needs to get that much further in order to engage with the speedometer cable
use the one that CAME from your vehicle.
it should engage, I see no reason why it shouldn't. in case you don't know, the speedo gears were pretty much interchangeable.
worse thing comes to worse, disassemble your tail housing from the old t-case and same on the new one, then swap the drivers out.
and no, it won't be too long. stick the gears in both "mounts" (sensors) and compare them. they'll stick out the same lengths.
do i swap the plastic gear from the new case over to the old assembly? I'm gonna need you to spell this one out for me i am so confused.
christ NO!
in other words, the one that was IN YOUR TRUCK when you took it apart is the one you need, UNLESS you've lifted the truck and put larger-than-stock, in which case you need to order the correct one.
The short and long shaft speedo gears are not interchangible. 87-91 used the long shaft, 92+ used the short shaft. It sounds like you swapped in the 92+ tcase on the left. So you will need a 29 tooth short shaft speedo gear IF you did not change tire size and/or regear. See here for the part numbers:
http://gojeep.willyshotrod.com/HowtoSpeedoGears.htm
The plastic gear can be pulled from the steel shaft and swapped. I did it to mine. Just be sure to rotate the gear housing to the proper orientation so that the gear teeth are in the proper spot.
:agree: That too. Forgot that one Pete. :D
That's why I mentioned he could use the gear of his choice and put it on the proper shaft. I just used the tooth count closest to the ideal.
you guys haven't noticed...
he doesn't have an electric speedo. he HAS to use the long shaft.
I think (not positive) the pickup assemblies (electronic or mechanical) are swappable on the housing. In his original pic, the one on the left was electronic. Mine's a 91 w. the electronic speedo and uses the long shaft gear. But Pete's way of just swapping the shafts will work fine.
nope. that electronic sender is from a 93 or 94+ t-case it looks like, which are plastic and don't attach to the long shaft one or vice-versa.
IF you look closely, you'll see that the long shaft one has the shaft offset. the reason for this is so you can clock it in depending on gear diameter. just turn it to one of the 4 positions, and it will work.
again, use the ORIGINAL gear unless you've changed gear size.
My 91 must be an oddball between-the-years thing then. My speedo gear uses the long shaft, has the electronic speedo, and the electronic pickup in the picture is identical to mine. And I have the shaft offset groups for the different diameter gears. The housing is the same as the long shaft housing too in the picture, and it looks like the mechanical and electronic pickups will interchange. But maybe only on the 91 model I suspect now.
91 was the preliminary year. it used the RH pictured (longshaft) unit with the electronic sensor screwed on to it, instead of molded into it as the one on the left is. I believe that went until 93 or 94.
What he said.
Got it - thanks. I'm severely limited to 1991 HOs; I don't have a multi-year fleet like you guys. :cheers:
What he said.
lol...dammit i have to fix that.
again, use the ORIGINAL gear unless you've changed tire size.
sadly I'm probably gonna be the most hated person on here. I've sent 9 comanches to their graves, robbed of all dignity (and parts).
and I've had one of every year from 86 to 90. no 91's or 92's.
