does anyone know what the up arrow on the left hand side on the dash means?
also what other lights come on in that panel?
kevin
One of Jeep's stupider ideas. Even my 98 TJ has one. Amazing how quickly your brain completely ignores it. I shift when I want to, not when the idiot light tells me to.
Pop the cluster out and pull that stupid bulb out. Your sanity will thank you.
When it goes off is based on RPM, nothing else. That's why it goes off in 5th, and my old XJ used to throw it at me in reverse too.
Apparently, the newer ones go off of a memory system, they're supposed to remember the last RPM you shifted at, and go off then the next time.
