Moosieus Posted Tuesday at 01:23 AM Posted Tuesday at 01:23 AM Throwing this thread together quickly on how I sourced a tonneau cover for my short bed. In brief, no one makes tonneau covers or bed covers for the Comanche, so we're relegated to next best sizes for other truck models. neverrust.net has this useful reference table for finding next best fits. I had Claude gin up a quick bounds check against that. I took another quick pass this evening to make it more share-able as a gist. I'm providing that more for posterity than anything. Use with your own measurements at your own risk! Running the script with the measurements I took off my '91 Eliminator yielded this output: Beds with outside length 71.5-75 in. and outside width 55-60.5 in.: Make Model Years Outside LxW Inside LxW ---------- ----------------------------------------------- --------- ----------- -------------- CHEVY/GMC GM Compact/Midsize Truck, S10/Sonoma, Short Bed 1982-1993 75 x 60.25 71.25 x 55.375 DATSUN D-50 Short Bed 1962-1971 74.5 x 58.5 ? x ? DODGE Dodge Compact Truck, Ram 50 Short 1987-1997 74.5 x 60 ? x ? JEEP Commanche Short Bed 1986-1996 75 x 60 ? x ? MAZDA Cab Plus 1986-1993 74.5 x 60 75 x 50 MITSUBISHI Triton, Short Bed 1987-1996 74.5 x 60 72 x 55.75 NISSAN Nissan Short Bed 1985-1986 74 x 58.5 72 x 53.5 NISSAN Nissan Short Bed 1983-1984 75 x 60 73 x 55 8 of 124 beds matched. Another 41 in the chart have no outside dimensions listed and couldn't be checked. Bed dimensions courtesy of NeverRust: https://neverrust.net/cross-reference-chart-for-pickup-truck-bed-size-dimensions/ It's not especially novel information, but this at least corroborated that the 1st gen S-10 was a damn close fit, enough that I opted to act on it. I ended up purchasing this "DNA Motoring New Upgrade Truck Bed Top Hard Solid Tri-Fold Tonneau Cover Compatible with 82-93 S10 / 82-90 S15 / 91-93 Sonoma 6Ft Bed, TTC-HARD-039" off of Amazon. Here's a photo from my build thread along with some additional fitment photos. The lip of my tailgate is beat up, and it needs new bumpers (which I have from Key Parts), leaving a pinky finger sized gap in the center. If I wanna be especially particular (and I especially am), the cover was a hair small when I got it and has since settled to the best I could ask for. In conclusion: Based on the above chart and my anecdote of a single successful purchase, I'd say the best proxy size to shop for is a 1st gen S-10.
Moosieus Posted Tuesday at 01:52 AM Author Posted Tuesday at 01:52 AM While we're on the subject, I feel it necessary to reiterate that the external dimensions of the bedside panels are not square. They taper towards the rear end as pictured below. Here's a photo of the Comanche specific bed cover that came on my truck (gifted to another Comanche owner). If you look closely, you can see it's built square and does not follow the taper. As a practical matter, I don't think any manufacturer ever would on account of the complexity. So it's just the way these trucks are at the end of the day :)
fiatslug87 Posted Tuesday at 02:12 AM Posted Tuesday at 02:12 AM Nice. Are all three panels the same size, ~25”? Thanks.
Moosieus Posted Tuesday at 03:24 AM Author Posted Tuesday at 03:24 AM Took the best photos I can, camera lens plays tricks though. Here's the folded configuration. I also have the uncompressed images attached in a zip at the end. The first one is 25" on the money: Here's the next segment: and where the end lands there. bed_cover_photos.zip
ghetdjc320 Posted Tuesday at 01:37 PM Posted Tuesday at 01:37 PM Just to put this out there as it frequently gets missed: Truck Covers USA makes what I’d call the best bed cover specific for our trucks. It’s about 2k, and a top quality unit.
llhat Posted Tuesday at 02:26 PM Posted Tuesday at 02:26 PM i have a ?? Pendaliner?? bed liner in my 1989, was in it when I purchased truck in 1997, the liner covers the top ledge of the bed sides.... would the cover you link and used fit? Installation is drilling the top ledge of the bed? think i have an aluminum top edge cover on my tailgate...
fiatslug87 Posted Tuesday at 06:00 PM Posted Tuesday at 06:00 PM @Moosieus Do you think the panels can be separated? Thanks for the pics.
Moosieus Posted Wednesday at 03:45 AM Author Posted Wednesday at 03:45 AM 13 hours ago, llhat said: i have a ?? Pendaliner?? bed liner in my 1989, was in it when I purchased truck in 1997, the liner covers the top ledge of the bed sides.... would the cover you link and used fit? Installation is drilling the top ledge of the bed? think i have an aluminum top edge cover on my tailgate... The particular tri-fold I linked uses this style of clamp on the bedside rails. If your bed liner leaves them accessible it'll work, otherwise you may need to modify the liner.
Moosieus Posted Wednesday at 04:25 AM Author Posted Wednesday at 04:25 AM 9 hours ago, fiatslug87 said: @Moosieus Do you think the panels can be separated? Thanks for the pics. Anything can be separated with sufficient employ of implements of destruction As to the spirit of your question, there's some exposed 3mm hex screws on the hinges, but removing them yielded nothing but the screw itself: I peaked under one of those foam blocks what little I could, but I didn't find any hidden fasteners. My superficial assessment is, one may be able to tease it apart with a craft knife set, some pry tools, and maybe a heat gun for potential adhesives. I don't see a means via fasteners alone.
fiatslug87 Posted Wednesday at 05:34 AM Posted Wednesday at 05:34 AM Thanks, appreciate you trying. I’m thinking of a way to use a hard cover like this with the sport bar. The first piece being 25” would go past the kickers (in my SWB) allowing sections 2 & 3 to fold. The trick is getting the first piece in between and around the sport bar. One more question, how thick is the cover at the bed rails?
llhat Posted Wednesday at 01:50 PM Posted Wednesday at 01:50 PM 10 hours ago, Moosieus said: The particular tri-fold I linked uses this style of clamp on the bedside rails. If your bed liner leaves them accessible it'll work, otherwise you may need to modify the liner. thank you my liner is solid up the sides, there are fairly large head screws that seem to retain the liner and the liner covers the rail. Installation based on you image would require large cuts in the liner for that type of clamp arrangement. response is appreciated.
Moosieus Posted 20 hours ago Author Posted 20 hours ago On 11/18/2026 at 12:34 AM, fiatslug87 said: Thanks, appreciate you trying. I’m thinking of a way to use a hard cover like this with the sport bar. The first piece being 25” would go past the kickers (in my SWB) allowing sections 2 & 3 to fold. The trick is getting the first piece in between and around the sport bar. One more question, how thick is the cover at the bed rails? 1 1/4” roughly!
