MJKally Posted September 26 Posted September 26 I'm working on getting my 1990 4.0 Comanche back on the road, it's sat for 20 years and many things aren't working. The entire gauge cluster was dead, so I recently took it out, cleaned all the contacts and checked them all for continuity. The gauges mostly work now, except my tach is reading below 0 when the engine is running. If I give it some gas, the needle does go up, but the resting position while it's running is this: I have an original service manual with electrical diagrams, but it doesn't make it obvious where the wiring for the tach goes, or what to do if it's out of calibration. I've already gone through and cleaned as many grounds as I could find, all the connections in the IP seem to be good now. What would cause this?
Eagle_SX4 Posted September 26 Posted September 26 It is a good sign that the tach moves when revving the engine. That means the needle was probably removed at some point and put back on incorrectly. With the engine off, take the plastic lens off the cluster then simply pull the needle off with your fingers then press it back on while aligning it to zero. I had the same issue when I got my truck. Although it was clear my gauges had been messed with as there was aftermarket gauge faces on it. The gauge faces on yours are original.
MJKally Posted September 26 Author Posted September 26 I had the whole cluster apart to clean the contacts last week, I didn't remove the needle but it's possible I knocked it or disturbed it while it was apart. I'll try that, thanks! I've ordered a renix engine monitor, so I can check to see if it's calibrated with that whenever it turns up.
MJKally Posted September 26 Author Posted September 26 I ordered it from NickInTimeDesign.com, someone I know with an XJ recommended it to me, and I think someone on the forums did too.
pizzaman09 Posted October 1 Posted October 1 I had the same issue with bumping my oil pressure gauge needle when I cleaned my cluster. @Eagle_SX4 is spot on with the fix.
boxyjeep Posted Monday at 03:13 AM Posted Monday at 03:13 AM Good chance the needle has over-rolled. Rotate it counterclockwise by hand and see if it works properly thereafter.
