jodawill Posted August 5 Posted August 5 I have two questions here. First, what screw goes into this hole above the B pillar? Is it one of these three machine screws in the photo? Second question. If it is these screws, where does the third one go? Am I missing it on another piece of trim somewhere? I haven't noticed any other screws missing. Or is it used to hold the jack in somehow? I can't remember.
fiatslug87 Posted August 5 Posted August 5 Those three hold the inner door handle plate in place. The one in the b-pillar is a Philips pan head screw.
jodawill Posted August 5 Author Posted August 5 Thanks! I can't believe I forgot about the door handle. I'm in trouble though because I can't find those two for the pillars. I hope they turn up. But I guess it doesn't constitute an emergency.
ghetdjc320 Posted August 5 Posted August 5 The Dorman GM interior trim screw kits have that screw in their assortment. I bought several of those kits and have been able to use them all around the jeep for trim screws.
TheNerfsmith Posted August 5 Posted August 5 On that topic, When the previous owners swapped over a cherokee interior (I documented this on my build thread) a lot of the fasteners for dash and interior are now missing. Is there a kit that widely includes all the fasteners for the MJ's Interior?
ghetdjc320 Posted August 5 Posted August 5 3 hours ago, TheNerfsmith said: On that topic, When the previous owners swapped over a cherokee interior (I documented this on my build thread) a lot of the fasteners for dash and interior are now missing. Is there a kit that widely includes all the fasteners for the MJ's Interior? Sounds like something @boxyjeep might offer. Otherwise, the interior screw assortment from Dorman works very well, granted, there will be several in the kits that isn’t used.
boxyjeep Posted August 6 Posted August 6 Screw assortment: https://boxyjeep.com/products/interior-screw-assortment-jeep-xj-mj Caps: https://boxyjeep.com/products/interior-trim-bolt-hole-caps A Pillar Retainer Fix: https://boxyjeep.com/products/a-pillar-trim-repair-domes
ghetdjc320 Posted August 6 Posted August 6 47 minutes ago, boxyjeep said: A Pillar Retainer Fix: https://boxyjeep.com/products/a-pillar-trim-repair-domes Ok, that’s an awesome product!! Very clever solution to a very common problem. Do you know if these would also fit the b pillar trim upper screw hole? The one just above the courtesy light.
boxyjeep Posted August 6 Posted August 6 13 hours ago, ghetdjc320 said: Ok, that’s an awesome product!! Very clever solution to a very common problem. Do you know if these would also fit the b pillar trim upper screw hole? The one just above the courtesy light. Thanks! I haven't tested it on the B-Pillar but believe it should work.
Salvagedcircuit Posted August 9 Posted August 9 The b-pillar plugs are a slightly different size. when I cad'ed up some for my interior, the ones on the A-pillar did not fit snug in the b-pillar. I have the cad somewhere. its been a while.
jodawill Posted Monday at 05:31 PM Author Posted Monday at 05:31 PM So does anyone know the specs on the B pillar screws? I found one of them, but the other is MIA. Hopefully it turns up eventually...
boxyjeep Posted Tuesday at 04:28 PM Posted Tuesday at 04:28 PM 22 hours ago, jodawill said: So does anyone know the specs on the B pillar screws? I found one of them, but the other is MIA. Hopefully it turns up eventually... The screw packs that I sell will work. Along with the MJ B pillar caps.
