Change in plans, needs to be looked over.
How should I lift the rear about 3"?
4 members have voted
  1. 1. How should I lift the rear about 3"?
    • Bastardized leaf pack
      3
    • Dropped spring hangers
      0
    • Longer shackles
      0
    • Buy Add-A-Leafs
I needed some more lift than the 1-3/4" lift spacers I bought, so I went back to the suspension shop, and asked em about stacking spacers. They recommended changing coils.
They happened to have a set of 3" lift coils they took off an XJ that were only on for a week. I bought em for $100, basically new, only the truck won't start with a 20" lift due to having new springs. I guess they sold them for $160 to the other guy, so I saved a little money.
3" lift in front... just swap the coils? Do I worry about brake lines or links or anything?
Here's the real question area... the back. To start things out, I'm pretty poor right now. I want to try to match the front end lift too.
I have an extra set of leafs I took from a different suspension shop's trash pile. I don't know what they're from, but they're the same width as an MJs. Can I take a leaf out of that and bastardize my leaf pack for the lift?
My dad thought a different idea could be to drop the spring hangers. Weld on lower hangers for the shackles to hang by and for the front of the springs to hang by. How's this idea to you guys?
A 3" shackle lift I think'd be too big (I can make them myself, so no price problem), but any thoughts on this?
Do they make 3" lift springs, or is it AAL?
A reference photo for the spring hanger idea. (Not a good one though, lol)
Image Not Found
I know skyjacker has a 3" long AAL, I've got one.
I second petes recomendation.
You will need to relocate the front brake lines. Unbolt the bracket that holds it to the body, then bend it down a bit and re attach.
You should probably look at the rear line too, and get a replacement if it's not long enough.
What's the thought on making new spring hangers?
IMHO ... bad idea. As already commented, they'll get hung up on things. ("Things" usually meaning rocks, but can also apply to tree stumps, old fences, dead cows ... whatever you're trying to over instead of around.)
My '88 MJ had a 4" Trailmaster lift when I bought it, with the front control arm drop brackates. Same idea. I hated them. Rock magnets, is what they are.
Sounds good. I think I'll bastardize, and for any extra lift height, I'll extend my shackles.
Already relocated my brake line bracketry, and the engine comes in Friday. Feels odd, like I'm doing this all backwards, but this is how I have to do it right now.
I would get a long AAL. They aren't that much money.
Don't forget that any change in front height will throw the alignment off.
I used Rusty's long AAL and am happy with them. Got just over 3". Very reasonable price too.
